Thread: Question about how much boost I'm running?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 115
  1. #41 Re: Question about how much boost I'm running?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    how dare you bad mouth zzp...they have an 8.65 1/4 mile car ...
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  2. #42 Re: Question about how much boost I'm running?
    Quote Originally Posted by ScottyDoggs View Post
    not the same. your l36 is high compression, where the l67 is lower. you dont have l67 heads either, another restriction i guess.
    and because of the higher compression. and we cant run the same timing as a l67 can. our timing is lower.
    when you rev the engine from under the hood, does the lever on the bbv move?
    Scott afaik the l67 and l36 heads are 100% the same minus the injector bungs. So they flow the same.
  3. #43 Re: Question about how much boost I'm running?
    Kemmerer, Wyoming
    Quote Originally Posted by J57ltr View Post
    This sounds strangely familiar...... If zzp programmed the computer then they must have basically set tables for running the thing as a speed density system above atmospheric pressure, since a 1 bar map will only read to atmospheric. The output of a map sensor is 0-5V, a 1 bar is close to 0 at full vacuum (about 29"Hg) to 5v at atmospheric (0"Hg/0psi) a 2 bar MAP reads 2.5V at atmospheric pressure and goes up to 5V, at 14.7 psi or so (correct me if I am wrong, please). So basically after you reach atmosphere pressure or 0psi the PCM can no longer "see" any boost and would have to refer to preset tables based on airflow and SD or strictly Speed Density, but then again how can it when it doesn't have a good signal from the MAP.
    that is exactly true. a boost gauge only reads what the sensor says, and a 1 bar sensor is going to say very little. I doubt there is a single car company in existence today that uses a 1 bar map sensor.
  4. #44 Re: Question about how much boost I'm running?
    Quote Originally Posted by Tonkin2000GT View Post
    Yes the bbv does move and it whines real loud. Yea I think the higher compression is from the heads so I've heard like a 3.4 pulley on my setup is like a 3.2 or 3.3 on a gtp so it should be higher?
    The higher compression is from the pistons.
  5. #45 Re: Question about how much boost I'm running?
    its just your doing it wrong. no tough guy bs here. your not getting it or you refuse to try to understand whats going on cause ZZP is god?
    if you say they need to re flash the pcm to change the map, do that.
  6. #46 Re: Question about how much boost I'm running?
    GXP Level Member
    Mar 2015
    Tomball
    We aren't being hostile, it just comes across that way.
    when I bought my 05' it had a 3.4" on it and didn't have any mods really and at first it would go into boost then all of a sudden it wouldn't go into boost no matter what I tried. It took me weeks of testing this and that, buying a mechanical boost gauge then a Torque app to use with a BAFX to scan and see what the hell was going on. If I eased onto the throttle I could get to 5psi then it would drop to 0 and stay there both on the mechanical gauge and the Map output. It was frustrating to say the least. Boy you should have seen the ruckus that caused. My blower screemed, but the car would actually go into limp home and shut me out of the throttle (DBW car). Turned out that the previous owner had put a stinking check valve into the outlet to the gauge and Map. My car had fits. Granted this is not what your car is doing, but it begs the question how does zzp calculate load when all it has to go on is the MAF?
    Jeff
  7. #47 Re: Question about how much boost I'm running?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Thats why im on the forum to get other advice... Unfortunately I live in an area where there aren't any good shops close to me to tune or dyno tune the car since I have only zzp to tune I go with what they say and alot of this tuning is new to me.
    http://s300.photobucket.com/user/bra...5vqp4.jpg.html
  8. #48 Re: Question about how much boost I'm running?
    Replace those coils with stock ones the MSD coils will die sooner or later and are actually worse than the stock ones.
    Before you do any more mods to your car I really suggest you read this thread, then read it again and again. http://www.grandprixforums.net/threa...00-Powered-Car!!
  9. #49 Re: Question about how much boost I'm running?
    cant see whats going on there. take some pics that show where one end of a line starts and ends. all i see are t some white connectors and clear tubing with a compression fitting on it.
  10. #50 Re: Question about how much boost I'm running?
    GXP Level Member
    Mar 2015
    Tomball
    Is that your MAP right at the regulator? Do you have a Barometric pressure sensor as well?
  11. #51 Re: Question about how much boost I'm running?
    that baro is 04 up crap jeff.
  12. #52 Re: Question about how much boost I'm running?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by SgtMarshal View Post
    i doubt that is the case you only need a 2 bar on a car that sees positive manifold pressure. A 1 bar would actually have twice the resolution on an NA car since you are dividing 29"-0 between 5V instead of 2.5v
    I'm sure that most all NA cars built today have 1 bar maps. There isn't a reason to use a 2 bar.
  13. #53 Re: Question about how much boost I'm running?
    GXP Level Member
    Mar 2015
    Tomball
    really? I thought I saw the larger old style Map style sensors on the L67's in the JY as well
    Ford had them as well......
  14. #54 Re: Question about how much boost I'm running?
    only thing on the back side of the sc is the map, and the evap purge solenoid. thats it. both have vac lines to them. evp has one in and out. map just to it.
    looking closer at your pic zoomed the f in. i think you got some issues the way the lines are routed. please get some cloe up picks of the lines coming and going.
    i will say its damn clean and looks pretty damn good under the hood. i think you got a bug or two to work out tho.
  15. #55 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Thanks man yea EVERYTHING in the motor is brand new only has 5,000 on it thats two summers of me driving lol. Are the msd coils that junk? I just find it hard to put old stock ones on when those are like new. Here are some more pics this is how zzp told me to set it up.
    http://i300.photobucket.com/albums/n...psqfcalpq5.jpg
    http://i300.photobucket.com/albums/n...psixfnrmyn.jpg
  16. #56 Re: Question about how much boost I'm running?
    Most of them die within a year, but that is also on a car that is used daily so they might a little longer if you haven't put that many miles on them, and yes the stock coils were even tested by ZZP to be better than the MSD ones, its actually on their list of things that you shouldn't replace. I'll have to dig up the link for that.
  17. #57 Re: Question about how much boost I'm running?
    what you have should work, but its not really right. you should be using that vac tree on the blower where you have it capped off.
    being you have a 97 blower this is how it should be routed really. i know your map pig tail is to short to be on the back side, but run the lines to from where it says to.
    your boost gauge line. run that between the nipple under the snout and the map sensor.
    dont worry about the stuff you dont have like the evap. and the bbv actuator. as long as the port on the TB is capped its cool.
  18. #58 Re: Question about how much boost I'm running?
    Dec 2014
    Maryland
    MSD plug wires are also prone to failure.
  19. #59 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Okay so just basically run my fpr to any port on the tree? You think that i have to many on one? Is this affecting anything with my boost? What do you think about zzp high voltage coils? Or run stock?
  20. #60 Re: Question about how much boost I'm running?
    Dec 2014
    Maryland
    stock coils and stock wires. ac delcos
  1. running your got with no boost?
    By hollas13 in forum General Tech Discussion
    Last Post: 05-03-2014, 07:34 PM
  2. Running on full boost!!! AAAHH!!!
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2012, 04:13 PM
  3. car is running low boost and is throwing a p1646
    By sseigtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2012, 09:32 PM
  4. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  5. How many pounds of boost should I be running?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 01:36 PM
