Thread: Question about how much boost I'm running?
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 115
  1. #1 Re: Question about how much boost I'm running?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Yea my bad... Does that sound about right though? I was hoping for at least 10 that's why I'm asking. I am running 0 KR on this setup. I plan on pulling the motor back apart this winter though going with xp cam, ls7 lifters, 7.00 comp push rods, double roller, 140lb valve springs, with a 3.1 pulley.
  2. #2 Re: Question about how much boost I'm running?
    with only 6 psi boost i hope not lol im top swapped too with lightly ported heads 1.05 roller rockers, sd headers and a stock pulley that see's 6.5 boost. with the 3.4 on there i was @ 8 psi part throttle and kr out the ass, so it had to go.
    im really bottom swapped, my car came with a l67 and it took a crap. so i used a l36 bottom end.
    and you need a ic to run that pulley. 3.4 is pretty much the wall with out a ic, or e85.
  3. #3 Re: Question about how much boost I'm running?
    GXP Level Member
    Mar 2015
    Tomball
    I defer to Scotty on that one, he says your low.
  4. #4 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    So any ideas why my boost is so low? A L36 block and L67 are the same correct? I know my heads are different.
  5. #5 Re: Question about how much boost I'm running?
    if you can post some pics of your vac lines too. you may have something messed up and dont know it.
  6. #6 Re: Question about how much boost I'm running?
    not the same. your l36 is high compression, where the l67 is lower. you dont have l67 heads either, another restriction i guess.
    and because of the higher compression. and we cant run the same timing as a l67 can. our timing is lower.
    when you rev the engine from under the hood, does the lever on the bbv move?
  7. #7 Re: Question about how much boost I'm running?
    Quote Originally Posted by ScottyDoggs View Post
    Scott afaik the l67 and l36 heads are 100% the same minus the injector bungs. So they flow the same.
  8. #8 Re: Question about how much boost I'm running?
    Kemmerer, Wyoming
    a 1 bar map sensor isn't going to give an accurate enough reading for the pcm to compensate for higher manifold absolute pressure readings. most cars these days will use 2 bar map sensors because 1 bar map's are old technology.
    I wouldn't bother changing pushrods unless you need a different length. you aren't going to get more performance out of a different set of pushrods. I would do the 130 lb valve springs instead of the 140's because you want to run the lightest spring to get the job done, and 130 is good for the xp cam. even with that upgraded harmonic balancer you got from zzp, I wouldn't rev that thing higher than 6300 because it isn't going to reduce vibration enough to go much higher. you will get a lot more out of your build if you do a set of ported heads with that xp cam, I recommend the ones that orangeL67 does on here, he doesn't charge near as much as zzp and you get a better product.
    as far as boost goes, more is not always better. boost from a supercharger increases the pressure inside the engine, so having low amounts of boost means you have the flow mods set up the way you should. I would do the 2 bar map sensor, and get the tune adjusted, I'm not real sure what would need to be changed, but after that happens if you still have low boost, you might be able to pulley down and then scan for kr
  9. #9 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by SgtMarshal View Post
    Yea I'm not really worried about the map I have a mechanical boost gauge hooked up. Zzp has it reving to about 6400 right now they said it's benificial to rev higher but not till i put heavier valve springs in. My heads are ported already and they said 7.00 push rods will get me to the happy place with a ls7 lifter stock is 7.05.
  10. #10 Re: Question about how much boost I'm running?
    Quote Originally Posted by Tonkin2000GT View Post
    you dont under stand the map. your sucks, the pcm cant read it well. why you need the 2 bar map wired in. you just cut the wires and solder on a new pig tail on and use the new map.
  11. #11 Re: Question about how much boost I'm running?
    Kemmerer, Wyoming
    a mechanical boost gauge and a map sensor are totally different. the pcm is going to use the map sensor to operate the engine. the boost gauge only shows you what is happening inside the engine. you really need to study how an engine works to understand why the different length pushrods are not necessary unless you take measurements and see that you need them. LS7 lifters are about the same length as oem lifters so most people don't change pushrods.
    it really seems that you believe everything zzp says without any question. you need to learn more about engines because everything zzp says may be true in some cases, but not entirely.
  12. #12 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Yea I understand how an engine works I built this myself.... I just thought the boost seemed a little low. Ls7 lifters have a tighter range then stock so you need to find the happy medium. Yes I do believe zzp haven't had a problem yet why wouldn't I go with them?????
  13. #13 Re: Question about how much boost I'm running?
    lord help you man. zzp sucks a dick on there info, most of it is bull sh it just so you buy parts. its what they do, sell parts you know.
  14. #14 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Yes the bbv does move and it whines real loud. Yea I think the higher compression is from the heads so I've heard like a 3.4 pulley on my setup is like a 3.2 or 3.3 on a gtp so it should be higher?
  15. #15 Re: Question about how much boost I'm running?
    The higher compression is from the pistons.
  16. #16 Re: Question about how much boost I'm running?
    some thing like that. i built boost so fast with the 3.4 on this set up now. i light footed around town for 2 weeks waiting for a puller lol
    its got to be the map not reading right, its sounds like your making full boost if you hear the sc screaming. does it feel like its pulling strong and hard? it should if your making full boost.
  17. #17 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Yea it pulls strong I just want more hp you can never have to much. How is my map reading wrong when I'm reading it from my mechanical boost gauge I plumed in?
  18. #18 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
  19. #19 Re: Question about how much boost I'm running?
    post some pics of what you did under the hood, eyes on will help most of the time, ask jeff lol aka j57ltr
  20. #20 Re: Question about how much boost I'm running?
    read marshals post, he said it pretty simple English
  1. running your got with no boost?
    By hollas13 in forum General Tech Discussion
    Last Post: 05-03-2014, 07:34 PM
  2. Running on full boost!!! AAAHH!!!
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2012, 04:13 PM
  3. car is running low boost and is throwing a p1646
    By sseigtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2012, 09:32 PM
  4. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  5. How many pounds of boost should I be running?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 01:36 PM
