not the same. your l36 is high compression, where the l67 is lower. you dont have l67 heads either, another restriction i guess.
and because of the higher compression. and we cant run the same timing as a l67 can. our timing is lower.
when you rev the engine from under the hood, does the lever on the bbv move?
