Thread: Question about how much boost I'm running?
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 115
  1. #1 Re: Question about how much boost I'm running?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    stock coils and stock wires. ac delcos
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  2. #2 Re: Question about how much boost I'm running?
    those coils are known to fail. oem is a better spark too. its been tested. clean and paint your stock coils red if you like the look.
    yes use the ports on the tree.
    i still think your map is a issue tho.
  3. #3 Re: Question about how much boost I'm running?
    Dec 2014
    Maryland
  4. #4 Re: Question about how much boost I'm running?
    Quote Originally Posted by EHB View Post
    Thank you, sorry I got caught up talking to Jeff in chat about rc stuff.
  5. #5 Re: Question about how much boost I'm running?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Okay will do. Is there differnt pressure on yhe tree then the manifold will give my fpr? Are all the ports on the tree the same? I looked on zzp and they have a 2 bar map sensor for a L36 so it just plugs in I'll probably change it over the winter when I get a tune. If you had what I have what would you do next for more hp would you pull the cam?
  6. #6 Re: Question about how much boost I'm running?
    a ic is your next move. or swap to e85.
  7. #7 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Okay so you don't think it would be benificial to put a xp cam in it? Zzp said I need stiffer valve springs and a double roller so minus well change the cam while it's apart they said like 20 hp from a gt1 cam to a xp.
  8. #8 Re: Question about how much boost I'm running?
    your call. for 20 hp idk if id be ripping the engine open again for that. you could do rockers for about the same cost and hp.
  9. #9 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Do coils go bad after a while or get weaker I should say? Should I put my stock ones on with 130,000 miles on them or buy new Stock ones?
  10. #10 Re: Question about how much boost I'm running?
    mine got 234,000 on em. working just fine.
  11. #11 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Yea I know but I need a double roller to put bigger valve springs in to run more boost right? Zzp wants me to run 140lb valve springs it seems like alot to me and hard on the valve train for the gains I've asked them several times they said 3800s just need to be sprung more even stock I don't know? I could put 105's on it with a single roller right? I mean its all new what rockers would you put on it with the cam I have though it's .507 lift intake and exhaust.
  12. #12 Re: Question about how much boost I'm running?
    the spring are for the cam so the valves dont float. nothing to do with boost.
    you dont do rockers with a cam, use the stock rockers.
    roller rockers like the 1.7 1.8. 1.9's all they do is let the valves stay open longer, but its the stock cams profile still.
    a cam has a more aggressive profile over the stock one, opening them more and closing the valves faster. why you need the springs to keep the valve in check.
    i forgot you had a cam already.
  13. #13 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Yea I understand that but the more boost you run you need heavier springs though cause of valve float right? They said if I put a ssic on I can run a 3.25 I'd like to get to 3.1 pulley they said that's aggressive with a ssic so change the cam and you'll be good. They said I'm border line right now with 90'some what springs do you run?
  14. #14 Re: Question about how much boost I'm running?
    Kemmerer, Wyoming
    the xp cam is going to change the powerband and put power in the higher rpms. I wouldn't rev higher than 6300. 6400 is probably too high with your current mods. I have an xp cam with 90 lb valve springs and I don't rev higher than 6300. I am planning on swapping to a set of 130 lb valve springs, intense has a set for sale, and I would venture a guess that zzp is suggesting the 140's because they have no 130's in stock. a lot of people run a 90lb or 105 lb with no problems, but the xp cam will do better with a 130 lb valve spring. the hp/tq curve will be more steady. even with the 130's I don't plan on revving higher than 6300.
  15. #15 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    I have so much invested on what I have not knowin I can't use a full size intercooler on my setup my heads are new with new ss valves, ported a decent amount (gasket matched) with a 3 cut valve job don't really want to change them. Unfortunately I can't run e85 because the closet pump is over an hour away so I'm limited to 93 octane.
  16. #16 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Okay yea they have 130's in stock they just want me to put 140's in for some reason. Are you going with a double roller with those 130's? I'm just debating on pulling the motor back apart for the amount of $ to hp gains I don't know if it's worth it.
  17. #17 Re: Question about how much boost I'm running?
    and why cant you use a fsic? if its the tb hitting you use a turn down. nothing is free.....
    stock chain cant handle them 130's or 140's. you need to use a double roller, and then you need to have it machined to fit right. more money spent.
    keep in mind the crank turns the timing chain, the chain turns the cam, those springs are harder to turn and wear on the stock chain fast killing it.
  18. #18 Re: Question about how much boost I'm running?
    Jul 2015
    Jamestown, NY
    Because I have the ssm90 setup my injectors go into my lower intake instead of in the head so when you raise the blower it raises the injector rail cuz the rail is bolted to the top of the blower. Zzp has stand offs for the injectors they sell to use the ssic but they said they can't get a full size to work because it's to much of a gap the injectors are on to much of a angle and the car doesn't want to idle right.
  19. #19 Re: Question about how much boost I'm running?
    Quote Originally Posted by Tonkin2000GT View Post
    I am pretty sure Frosty ran a fsic under his ssm90 kit before he went l67. http://www.grandprixforums.net/threa...-Lets-find-out
  20. #20 Re: Question about how much boost I'm running?
    im sure you can mod the fuel rail. how we all do it, unless we use fuel logs. but those likely wont work for your set up.
  1. running your got with no boost?
    By hollas13 in forum General Tech Discussion
    Last Post: 05-03-2014, 07:34 PM
  2. Running on full boost!!! AAAHH!!!
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2012, 04:13 PM
  3. car is running low boost and is throwing a p1646
    By sseigtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2012, 09:32 PM
  4. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  5. How many pounds of boost should I be running?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 01:36 PM
