Thread: Question about how much boost I'm running?
Results 1 to 20 of 115
  1. #1 Re: Question about how much boost I'm running?
    Kemmerer, Wyoming
    Quote Originally Posted by J57ltr View Post
    This sounds strangely familiar...... If zzp programmed the computer then they must have basically set tables for running the thing as a speed density system above atmospheric pressure, since a 1 bar map will only read to atmospheric. The output of a map sensor is 0-5V, a 1 bar is close to 0 at full vacuum (about 29"Hg) to 5v at atmospheric (0"Hg/0psi) a 2 bar MAP reads 2.5V at atmospheric pressure and goes up to 5V, at 14.7 psi or so (correct me if I am wrong, please). So basically after you reach atmosphere pressure or 0psi the PCM can no longer "see" any boost and would have to refer to preset tables based on airflow and SD or strictly Speed Density, but then again how can it when it doesn't have a good signal from the MAP.
    that is exactly true. a boost gauge only reads what the sensor says, and a 1 bar sensor is going to say very little. I doubt there is a single car company in existence today that uses a 1 bar map sensor.
  2. #2 Re: Question about how much boost I'm running?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by SgtMarshal View Post
    i doubt that is the case you only need a 2 bar on a car that sees positive manifold pressure. A 1 bar would actually have twice the resolution on an NA car since you are dividing 29"-0 between 5V instead of 2.5v
    I'm sure that most all NA cars built today have 1 bar maps. There isn't a reason to use a 2 bar.
  1. running your got with no boost?
    By hollas13 in forum General Tech Discussion
    Last Post: 05-03-2014, 07:34 PM
  2. Running on full boost!!! AAAHH!!!
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2012, 04:13 PM
  3. car is running low boost and is throwing a p1646
    By sseigtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2012, 09:32 PM
  4. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  5. How many pounds of boost should I be running?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 01:36 PM
