Originally Posted by ScottyDoggs not the same. your l36 is high compression, where the l67 is lower. you dont have l67 heads either, another restriction i guess. and because of the higher compression. and we cant run the same timing as a l67 can. our timing is lower. when you rev the engine from under the hood, does the lever on the bbv move? Scott afaik the l67 and l36 heads are 100% the same minus the injector bungs. So they flow the same.
Forum Rules
