Thread: About to begin my rebuild. Input needed
Results 1 to 20 of 23
  1. #1 Re: About to begin my rebuild. Input needed
    Jul 2011
    oregon
    34 degrees stock compression for high cr u have to start fighting knock and etc and that high cr was used with iron heads the max you can get out of iron heads in most applications is around 11:1 we could of pushed it past 38 degrees but the block saw no power change after 35 degrees so we kept it at 34 and hyper pistons his tune better be good, cause once he gets some knock those pistons will shatter I've shatter 5 hyper pistons b4 from a bad linkage to the secondary butterflys on the carb b4
  2. #2 Re: About to begin my rebuild. Input needed
    SE Level Member blown98gtp's Avatar
    Feb 2009
    iowa
    Quote Originally Posted by pushrod4life View Post
    the max you can get out of iron heads in most applications is around 11:1 .I've shatter 5 hyper pistons b4 from a bad linkage to the secondary butterflys on the carb b4
    I've got a 13:1 iron-headed 460 in a 83 cougar that runs just fine. Plenty of people run more than 11:1 with iron heads. It's called race gas. And please explain how a bad secondary linkage caused your pistons to shatter.
    98 gtp:L36/GenV/S1X/Pacesetters/FWI/Intense tune/timing commander/104s/P&P heads/DevilsOwn alky kit/ZEX dry shot/42.5#/shift kit/ScanGauge
  1. Total engine rebuild, advise needed.
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 09:07 PM
  2. Tools needed for rebuild?
    By TMC in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-16-2010, 11:16 PM
  3. Oklahoma/ Kansas Meet in May- input needed
    By TurboKent in forum Southwest
    Last Post: 05-19-2010, 11:44 PM
  4. input needed
    By UWISHU1 in forum General Tech Discussion
    Last Post: 06-29-2008, 10:46 AM
  5. Tranny Tools Needed for Rebuild
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 07:20 PM
