Thread: will this engine swap work?
Results 1 to 9 of 9
  1. #1 will this engine swap work?
    Aug 2011
    fredericksburg virginia
    Hey guys, im new to the site but not to Grand Prix's, i work at a Buick Gmc dealership (used to be Pontiac as well). anyways i have a 1998 gtp and back in 2004 we replaced an engine in a 04 l32 gtp for excessive oil consumption. so my question is will the block and heads work in my vehicle, according to the gm catalog the part numbers are different, was just curious if any of you know or have tired this, Thanks.
  2. #2 Re: will this engine swap work?
    it would work but it's not an upgrade or anything
  3. #3 Re: will this engine swap work?
    yes it will...
    The blower is worth holding onto.
    Could be sold for 250-350 by itself.
  4. #4 Re: will this engine swap work?
    Your L67 will adapt everything from the '04+ L32, minus the fuel system/TB setup that is...
    You can use the supercharger (GenV M90 vs. your GenIII), and the heads have slightly larger valves...
  5. #5 Re: will this engine swap work?
    i wasn't thinking about the sc i figured it was a block and heads
  6. #6 Re: will this engine swap work?
    Aug 2011
    it is just a block and heads, should of been more specific, sorry. and i knew it wouldnt be an upgrade but my engine has 178,xxx miles on it so in reality who knows how long it will last.
  7. #7 Re: will this engine swap work?
    utah
    Just use it and start building the l32 up for when yours takes a ****
  8. #8 Re: will this engine swap work?
    Aug 2011
    thats what i plan on doing, thanks guys for letting me know that this works.
  9. #9 Re: will this engine swap work?
    utah
    O yea and cam it!
  1. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  2. Drivetrain work (trans swap 5 hours)
    By BillBoost37 in forum General Tech Discussion
    Last Post: 05-09-2011, 09:20 AM
  3. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. Engine Work
    By MakeitLouder97 in forum Introductions/Noob Questions
    Last Post: 03-24-2010, 03:53 PM
