Thread: input needed
Results 1 to 7 of 7
UWISHU1 input needed 06-25-2008, 09:03 AM
archemedes Re: input needed 06-25-2008, 10:21 AM
UWISHU1 Re: input needed 06-26-2008, 09:12 AM
Warhellride Re: input needed 06-28-2008, 10:13 AM
UWISHU1 Re: input needed 06-29-2008, 01:15 AM
boosting98 Re: input needed 06-29-2008, 01:52 AM
archemedes Re: input needed 06-29-2008, 10:46 AM
  1. #1 input needed
    SE Level Member UWISHU1's Avatar
    Hanover Park, IL
    Hello, I'm tired of buying them after market driving lights (Pilot) that go out within a year. I'm on my 2nd set,and was wondering does th 97-04 GP driving lights fit a 95 GP?
    Thanks for your help.
  2. #2 Re: input needed
    Saraland Alabama
    why not replace the bulb in the pilots?
  3. #3 Re: input needed
    Hanover Park, IL
  4. #4 Re: input needed
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    The 97-03 GP foglights are 4", so if yours are also 4" than any 4" light should work. I don't know if the bracket is different for the pre-97 and the 97-03, but the stock 97-03 lights are worthless so I don't see why you'd want to use those. What bulbs do the Pilots use? You should be able to get longer lasting bulbs that won't blow in a year. If your problem is the glass lens breaking, you could cover them with the Xpel film to protect them.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  5. #5 Re: input needed
    Hanover Park, IL
    Thanks, the problems is the lights are getting water in them.
  6. #6 Re: input needed
    ^ sounds like a seal issue, not the bulbs!
  7. #7 Re: input needed
    Saraland Alabama
    maybe buy a better light instead of the cheap ones, or add a seal
  1. Integra/New GTP Input
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 06-10-2008, 12:26 PM
  2. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
  3. Need Some Input On a GP
    Last Post: 02-22-2008, 07:14 AM
  4. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
