Thread: About to begin my rebuild. Input needed
Results 1 to 20 of 23
  1. #1 Re: About to begin my rebuild. Input needed
    Jul 2011
    oregon
    Suggestion I would build your future block for water/meth setup you'll be happier with it if this guna be a track car lowers intake temps etc and allows more higher compression to be used vs e85 but that 9:75 sounds like a little to much on iron heads with some boost. It can work but u need a bigger cam than the vs or xp wit a lot of duration to bleed off the cylinders.Aluminium heads with the xp cam would work with thermal coated pistons .
  2. #2 Re: About to begin my rebuild. Input needed
    Jul 2011
    oregon
    But basic forged pistons with the ring end gaps open up a little more for the boost would work too
  3. #3 Re: About to begin my rebuild. Input needed
    HUDSON
    Quote Originally Posted by pushrod4life View Post
    YES! open the top ring gap, and forged pistons are great as long as the proper piston to wall clearences are met, and then they still might make a
    little bit of noise.
    BUT again, the most important part on ANY boosted application is the
    TOP piston ring gap, that is why so many STOCK engines blow up by
    breaking the top ringland OFF!!!!!
  1. Total engine rebuild, advise needed.
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 09:07 PM
  2. Tools needed for rebuild?
    By TMC in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-16-2010, 11:16 PM
  3. Oklahoma/ Kansas Meet in May- input needed
    By TurboKent in forum Southwest
    Last Post: 05-19-2010, 11:44 PM
  4. input needed
    By UWISHU1 in forum General Tech Discussion
    Last Post: 06-29-2008, 10:46 AM
  5. Tranny Tools Needed for Rebuild
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 07:20 PM
