Thread: A-Pillar
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
  1. #1 A-Pillar
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    How much will it roughly cost to get my triple gauge A-Pillar installed.
    1. Boost
    2. Air To Fuel Ratio
    3. Volts
    - All from GlowShift, Tinted 7 color series
  2. #2 Re: A-Pillar
    skip the A/F unless its a wideband gauge, the flashing bars gauge is just a light show and does nothing.
    Get, oil pressure, boost/vac and volts or spend more money and get a aerofocre scangauge if your going to continue to mod.
    Each gauge on glowshift is 35-60ish bucks, so with 2-3 thats already amost 100 and then add the pillar itself and thats another 50ish, so 150-200 on a rough guess.
  3. #3 Re: A-Pillar
    Jun 2011
    Whats wrong with the Air to Fuel Ratio gauge?
    - Its this one: Tinted 7 Color Needle Air / Fuel Ratio Gauge
  4. #4 Re: A-Pillar
    Donating Users
    South Deerfield, MA
    It is not accurate. It only references the numbers coming from the factory narrow band sensor through the PCM. None of us would spend money on widebands if that number was useful.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: A-Pillar
    Jun 2011
    I'm planning on doing mods to my car, but no for a long time because I'm still in school and don't make Alot of money at the moment. Hopefully by next year I'll start modding my car, so what's your opinion on the gauge I should get?
  6. #6 Re: A-Pillar
    Houston
    Definitely stay away from that A/F gauge. I had that exact one, except white face, in my car for 1 day and I removed it. It will do nothing but bounce from lean to rich and will drive you fuggin nuts. I replaced it with the oil pressure gauge.
  7. #7 Re: A-Pillar
    MO
    Guys? He's asking for installation costs.
    <brandonl2000> LMAO D!!
  8. #8 Re: A-Pillar
    Jun 2011
    I already have the A/F Gauge, maybe I can return it and get something else
  9. #9 Re: A-Pillar
    Ocala, FL
    Cost for installation? Nothing, do it yourself.
  10. #10 Re: A-Pillar
    Jun 2011
    I don't really know where the factory "T" is to replace the hose for boost, and I don't know where to hook up the wire for narrow air to fuel ratio gauge, and would I have to drill a hole through my firewall to get the wires through to the engine bay unseen? It's a pain to do that
  11. #11 Re: A-Pillar
    Houston
    You cut the vac line between the T under the snout and the MAP, then add a T. Connect the two lines you cut, along with the boost line.
    You connect the A/F to the rear 02 sensor, but no need to connect it unless you like watching the needle bounce back and forth from lean to rich. It is a pain to get the boost line through the firewall, but no drilling needed, there is a grommet under the brake booster on the driver side.
  12. #12 Re: A-Pillar
    Jun 2011
    Should I return my A/F gauge and get another one?
  13. #13 Re: A-Pillar
    yes, we already said the A/F is a pointless gauge.
    I told you, you should get boost/vac, oil pressure and volts or a aeroforce scangauge.
  14. #14 Re: A-Pillar
    Houston
    Yes, ditch it. You would get more use out of a clock shaped like a gauge.
  15. #15 Re: A-Pillar
    Jun 2011
    so oil pressure and not like all the trans temp and stuff? is oil pressure easy to install?
  16. #16 Re: A-Pillar
    Houston
    Well I can see my trans temp and everything else from my aeroforce gauge. The oil pressure gauge is easier than the boost gauge because you only need to run a small ass 18 gauge wire through your firewall. Basically:
    1. Drain engine oil
    2. Remove stock oil sending unit
    3. Buy 1/8 inch to 1/4 inch thread adapter (got mine at o'reillys)
    4. Install new sending unit that comes with the gauge
    5. Run sending unit wire through firewall to the gauge and connect the power and ground.
    This is where the old sending unit is (this is a pic of the sending unit that comes with the gauge)
  17. #17 Re: A-Pillar
    Jun 2011
    alright, ill see what i can do about returning the A/F gauge and getting oil temp. or something else. thanks for the help. One more question, what source should I use for the Constant 12v source? and for the "dimming" feature?
  18. #18 Re: A-Pillar
    Houston
    There isnt a dimming feature on the glowshift gauges. Just constant 12v, switched 12v and ground. If you look under your driver side dash, towards the steering column, you will see a group of wires. The red and the red/white wires are your constant 12v.(you can tap into which ever one you like) The pink wire is your switched 12v. And you can get a ground by just screwing in a self-tap screw into the metal knee basher plate. (you will see this when you remove the plastic cover...the one your knees hit if your seat is moved all the way forward)
  19. #19 Re: A-Pillar
    Jun 2011
    on my GlowShift gauges instructions, it says,
    1.) Orange: Switched 12v Headlamp source
    2.) Yellow: Constant 12v source
    3.) Red: Switched 12v source
    4.) Black: Ground
    whats the headlamp source then?
  20. #20 Re: A-Pillar
    Houston
    For which gauge?
  1. A pillar
    By TurosGTP in forum Visual/Body Modifications
    Last Post: 03-23-2016, 10:58 AM
  2. 3 pod A-pillar for 04+ gtp???
    Last Post: 03-21-2016, 08:39 PM
  3. Pillar Pod
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2010, 12:52 PM
  4. a pillar
    Last Post: 03-24-2009, 11:59 PM
