Thread: Need input on set up!
Results 1 to 18 of 18
GTP4 Need input on set up! 10-24-2008, 07:10 PM
Mikegotone\'02 Re: Need input on set up! 10-25-2008, 02:59 PM
GTP4 Re: Need input on set up! 10-25-2008, 08:57 PM
Guest Re: Need input on set up! 10-25-2008, 05:29 PM
GTP4 Re: Need input on set up! 10-25-2008, 09:01 PM
Guest Re: Need input on set up! 10-25-2008, 09:20 PM
GTP4 Re: Need input on set up! 10-25-2008, 09:28 PM
GTP4 Re: Need input on set up! 10-25-2008, 09:47 PM
Mikegotone\'02 Re: Need input on set up! 10-26-2008, 01:01 PM
GTP4 Re: Need input on set up! 10-26-2008, 05:51 PM
Guest Re: Need input on set up! 10-26-2008, 01:04 PM
GTP4 Re: Need input on set up! 10-26-2008, 03:02 PM
Mikegotone\'02 Re: Need input on set up! 10-26-2008, 03:18 PM
GTP4 Re: Need input on set up! 10-26-2008, 05:47 PM
Guest Re: Need input on set up! 10-26-2008, 01:10 PM
GTP4 Re: Need input on set up! 10-26-2008, 03:00 PM
  1. #1 Re: Need input on set up!
    TDCRacing
    Guest
    Do you have any TM disabled? I would think with the mods you have you could run a 3.2 without any issues......but then again every car is different.
    Other wise stick to the suggestions already given by Mike
  2. #2 Re: Need input on set up!
    Aug 2008
    SOUTH TEXAS
    Quote Originally Posted by TDCRacing View Post
    We tried changing the Tm settings, but it only made it worst.
    It resulted in more KR.
    Anything in particular i should change on TM?Or all settings?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  1. just want some input
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 01:18 PM
  2. looking for input
    By fratzke7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2008, 09:47 PM
  3. I am going to buy these. Please input.
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 07-02-2008, 06:55 PM
  4. Need Some Input On a GP
    Last Post: 02-22-2008, 07:14 AM
  5. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
