Thread: Need input on set up!
Results 1 to 18 of 18
  1. #1 Re: Need input on set up!
    TDCRacing
    Guest
    What are you're fuel trims at at WOT? They should be at zero. Like suggested you want the hottest spark that you can get without having any kr.
    The WOT section on the timing table on your car should be in this range.
    If you had HPT you could do one of these.Wich would be a timing tune.
    I could run about 22 degrees with no kr on 87....and 25 on 93...what are you using?
  2. #2 Re: Need input on set up!
    Aug 2008
    SOUTH TEXAS
    Quote Originally Posted by TDCRacing View Post
    I think last time we scan ltfs were locked at 0.
    Hottest spark, you mean spark plug?
    I use 93 all the time.
    Thanx for all the help guys!
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  1. just want some input
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 01:18 PM
  2. looking for input
    By fratzke7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2008, 09:47 PM
  3. I am going to buy these. Please input.
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 07-02-2008, 06:55 PM
  4. Need Some Input On a GP
    Last Post: 02-22-2008, 07:14 AM
  5. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
