What are you're fuel trims at at WOT? They should be at zero. Like suggested you want the hottest spark that you can get without having any kr.
The WOT section on the timing table on your car should be in this range.
I could run about 22 degrees with no kr on 87....and 25 on 93...what are you using?
I think last time we scan ltfs were locked at 0.
Hottest spark, you mean spark plug?
I use 93 all the time.
Thanx for all the help guys!
TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
