Thread: Need input on set up!
Results 1 to 18 of 18
  1. #1 Re: Need input on set up!
    Banned
    oswego
    Quote Originally Posted by GTP4 View Post
    Would i benefit more from running the 3.4" and adding timing, maybe 18-20?
    Or runing my 3.2" and runing only 16-17* to avoid kr?
    My mod are:
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2"//Ud plly//Msd wires//Aut 103's//CAI//DHP 1.0 Power tuned.
    Reason i'm asking, is because i ran a 13.6@100mph 1.9' with 17* timing on the 3.2" with blips of kr at the track.
    If i wanted to trap higher i would have to had added more timing,which= more KR.
    My car has been a pain on the a.... to tune.
    With 1.9's rr i traped 99.8mph can't remember the timing i was running.
    Any input is appreciated!
    Timing is everything my friend. I wish you have hptuners so i could take a look at some stuff that i'm pretty sure is causing you these problems. Every car is different yes, but that setup should not have to jump to a 3.4 to run 20* of timing. I'll bet there's some glitches in your tune that's killing you. I'm sure i can read a scan or two, why don't you post some up? There's plenty of darn good help on here to give you a pointer or two and maybe help work out your problems? FWIW I trap 106 non-i/c'd on 1.9 rockers, so... I would first change your plugs to 104's those 103 are way cold for that setup, another i have a feeling of a vac. leak, maybe check around for that?
  2. #2 Re: Need input on set up!
    Aug 2008
    SOUTH TEXAS
    Quote Originally Posted by Mikegotone'02 View Post
    We are tuning with a power tuner, so we can prolly post scans.
    Vacumm leak?I just might have one.
    104's over 103's why do i need a hoter plug?
    I thought colder was better?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  1. just want some input
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 01:18 PM
  2. looking for input
    By fratzke7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2008, 09:47 PM
  3. I am going to buy these. Please input.
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 07-02-2008, 06:55 PM
  4. Need Some Input On a GP
    Last Post: 02-22-2008, 07:14 AM
  5. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
