Thread: Simple Intake (pictures)
Page 9 of 23 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 454
  1. #161 Re: Simple Intake (pictures)
    pennsylvania
    what did you guys do with the computer in the intake box? I dont see any way of holding it still
  2. #162 Re: Simple Intake (pictures)
    just leave it there, its weather proof and shock proof.
    use some big zip ties if ya want to hold it down better.
  3. #163 Re: Simple Intake (pictures)
    pennsylvania
    i was just worried it would slide over to where the fans are or wires ripping but ill just zip tie her down thanks
  4. #164 Re: Simple Intake (pictures)
    Banned Trolling GPF
    i just COMPLETELY finished my intake...ive had several different designs on it...but this one is final lol, its nowhere close to hitting anything now, and it runs smooth...i used 4 inch pvc though...and left it white hehe
  5. #165 Re: Simple Intake (pictures)
    Feb 2009
    Virginia
    Quote Originally Posted by coreygnar View Post
    EVERYONE WHO HAS DONE THIS MOD READ THIS
    every once in a while you should pop the hood and make sure your intake is intact, i opened my hood the other day and my filter was about to fall off, the hose clamp had become loose. im sure most of you made this like nawarkk did with pvc, and the homedepot clamps, and i dont think this stuff is engine rated, it may become loose over time.
    I used a 3" coupler from siliconeintakes.com and I don't have any issues with the cone sagging or falling off. I did this a while ago, can't remember. Funny how I stumbled across the same cone as the author
    I have an 04+. The coupler is short enough that it becomes very rigid once it's forced on between the MAF and TB. I used the Spectre adapter ring deal on the actual MAF. For the sensor I just drilled a smaller hole than the sensor itself and let the silicone fold around it once it was shoved in. No leaks. Anyways, very sturdy and no issues on my part. Hope that helps other 04+
    Here's an image of my first iteration while I was waiting for the mail to bring the coupler...it had the saggy/falling off issue after just a week
    11 is louder than 10!
  6. #166 Re: Simple Intake (pictures)
    SE Level Member d8teen's Avatar
    Jul 2010
    Fl-Hollywood
    Hello my friends, just did litle mod of my own today, very proud and happy . Got everything needed for setup in the Menards store that is better home depot. Filter i have bought here: link to ebay. I Found it on forum somebody recomended and i fount its amazing deal. For 35 buks i got 2 awesome filters and 4 stikers . I saved one for other car or as replacement. So all calculated my mod came to be $27.89 with filter!
    Looks something like that:
  7. #167 Re: Simple Intake (pictures)
    London Ont, Canada
    How did you use the stock MAF "holder" ???
  8. #168 Re: Simple Intake (pictures)
    SE Level Member Smile's Avatar
    Jun 2011
    Ontario, Canada!
    now if you failed at a step, whats the worse possible thing that could happen? and how could you tell which step you failed at?
  9. #169 Re: Simple Intake (pictures)
    Ummm...wut.
  10. #170 Re: Simple Intake (pictures)
    West Side Michigan
    You can't really FAIL at making an intake..
    You have a tube and a filter at the end of it..
    What did you not do correctly?
  11. #171 Re: Simple Intake (pictures)
    you fail when it doesnt filter air.
  12. #172 Re: Simple Intake (pictures)
    Maybe he just bolted a piece of wood to the throttle body and it doesnt start.
  13. #173 Re: Simple Intake (pictures)
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    Awesome thanks for the write up nawarkk just finished and love the results I used a K&N Filter
  14. #174 Re: Simple Intake (pictures)
    Out West
    needs a blower.
  15. #175 Re: Simple Intake (pictures)
    Where's the clamp for the filter?
  16. #176 Re: Simple Intake (pictures)
    Jun 2011
    Saginaw Mi
    Lol that was before I put it on had to run up to autzone I didn't have any clamps that big
  17. #177 Re: Simple Intake (pictures)
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    is this a sturdy setup.does it move easily ?do you suggest making a bracket to hold it?
  18. #178 Re: Simple Intake (pictures)
    Quote Originally Posted by jpmiller View Post
    Use your man arms and make it tight with hose clamps.
    That sh1t doesn't go anywhere.
  19. #179 Re: Simple Intake (pictures)
    Jul 2011
    Michigan
    so whats the solution to the filers falling off
  20. #180 Re: Simple Intake (pictures)
    Norristown, PA
    Look at the post above you.
    fool.
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
