Thread: Simple Intake (pictures)
Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 361 to 380 of 419
  1. #1 Re: Simple Intake (pictures)
    Mar 2012
    Cincinnati
    Does yours also have the crazy loud sucking sound? I mean I knew the sound would change but the sucking sound on this thing is crazy lol
    1999 Grand Prix GTP
    GXP front brakes, Comp G wheels, Dual HUD pod, Aeroforce Interceptor & boost gauge, GMPP front & rear strut brace, catless downpipe & resonator delete, homemade short ram intake w/ K&N filter
  2. #2 Re: Simple Intake (pictures)
    Quote Originally Posted by Swole View Post
    Yes, it's normal.
    It's the air passing through the IAC passage inside the throttle body, the stock intake muffles that sound.
  3. #3 Re: Simple Intake (pictures)
    Dec 2012
    Where 4T65E's were born
    Should go away after it warms up and the iac valve closes. Mine's loud on cold startups too but after 10 mins of idle, or after putting it in gear it stops.
    Sold.
  4. #4 Re: Simple Intake (pictures)
    GT Level Member Bogers04SS's Avatar
    Feb 2010
    Mocksville, N.C.
    Or you could make a simple one like this...
    Works great, and pop out the headlight at the track and its a funnel for the intake...we'll see if it makes a difference here in a few weeks when Friday Night Thunder starts back up at Farmington....
    04 Impala SS -- SOLD
    08 Prix GXP -- FWI, 3in DP, TR6IX plugs, Ported & polished throttle body, ported intake manifold, DiabLEW Tuned, wrapped crossover pipe, Cat delete, Factory res., Muffler delete, Poly motor mounts, shift kit, LED bulbs in just about every Da*n thing, ect..
  5. #5 Re: Simple Intake (pictures)
    Florida
    Elbow is from Home Depot or Lowes. Use any air filter you want. The rubber connectors are also from lowes/hd
    just air filter, plastic elbow, connectors, and paint
  6. #6 Re: Simple Intake (pictures)
    Dec 2012
    St. Paul
    So some of these guys..
    http://www.menards.com/main/building...210-c-5776.htm
    then get this guy...
    http://www.menards.com/main/plumbing...654-c-8547.htm
    and drill a 1/2" hole for the sensor and then were did you get the grommet?
    2007 GXP
  7. #7 Re: Simple Intake (pictures)
    Mar 2012
    Cincinnati
    Quote Originally Posted by Schmidty View Post
    Yes on the second link. The first link are just clamps. Here is sorta what the rubber coupling I bought looks like. It has this metal sheet around it that the clamps are connected to. Just break the clamps off of the metal sheet and just use the rubber and clamps. http://www.menards.com/main/plumbing...878-c-9371.htm
    I got the rubber grommet at Ace. It was in their nuts and bolts section in one of the drawers. They had very few but you need one with a 1/2" inner diameter for the sensor to fit snug into. Then I got some silicone adhesive to make sure the seal was tight.
    1999 Grand Prix GTP
  8. #8 Re: Simple Intake (pictures)
    Aug 2013
    McDonald PA
    You have a maf the whole is for the iat sensor that the 97-03 have just incorporate the maf. And if you have a vac line. Like I did being an 06 drill a hole into the rubber coupler slightly smaller and jam it in there
  9. #9 Re: Simple Intake (pictures)
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    Just did this on my car. Thanks for the write up! K&N 9" FTW!!! Loud as Betty when she screams my name
  10. #10 Re: Simple Intake (pictures)
    SE Level Member Luckys99GTP's Avatar
    Apr 2014
    Just did this setup on my 99 and Holy Fudgesicles does that S/C whistle! Thank you so much for the writeup, can't wait to get her out on the highway on my way to work tomorrow!
    Sent from my SCH-I545 using Tapatalk
    Using Tapatalk
  11. #11 Re: Simple Intake (pictures)
    Apr 2014
    Iowa
    Just made myself one of these i think i will be upgrading to an aluminum pipe that is a little longer and when i can make my way to the junk yard get a pcm mount. I dont have that throw ya back in the seat effect anymore when the supercharger kicks in i am still getting full boost and everything seems fine love the sound but am not sure if i am now getting less power or what is happening. Is more air allowing the motor to not have that sudden jump in pressure i am used to and giving me a smoother range?
  12. #12 Re: Simple Intake (pictures)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Have you cleaned your MAF at all? Skip the PCM mount just throw a bungie or zip tie around it.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  13. #13 Re: Simple Intake (pictures)
    SE Level Member jimzssei's Avatar
    Sep 2014
    From the almost dead... On the cheap, 4" ... Torque steered, whined and smiled uploadfromtaptalk1415746074759.jpg
    Sent from my couch
  14. #14 Re: Simple Intake (pictures)
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    and now your engine can enjoy that hot under the hood air......
  15. #15 Re: Simple Intake (pictures)
    Apr 2012
    Dayton, OH
    Mine loves hot air
    2012 F150 STX
  16. #16 Re: Simple Intake (pictures)
    Oct 2013
    michigan
    just thew mine on yesterday. was expecting a large amount of noise from reading some of the comments on here. can hear the blower some more but nothing what i had i mind.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  17. #17 Re: Simple Intake (pictures)
    Cold starts can sound like a shovel on concrete depending on ambient temp and once you drop pulley size the sound comes alive.
    Stock pulleys just don't spin it fast enough for alot of whine.
  18. #18 Re: Simple Intake (pictures)
    Oct 2013
    michigan
    yah i have a smaller pulley on that was given to me but never measured it, i should. updated sig, hadn't been on here in some time.
  19. #19 Re: Simple Intake (pictures)
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Do you have a press on pulley? The mps pulleys have the size written on the side
    Nice intake btw
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  20. #20 Re: Simple Intake (pictures)
    Oct 2013
    michigan
    yes I do but there was no definitive markings on it denoting size. and thanks!
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
