Thread: PCV problems-Related to I/C
Results 1 to 20 of 27
  1. #1 Re: PCV problems-Related to I/C
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    No problem
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: PCV problems-Related to I/C
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Do a compression test. #s greatly vary but are often in the 155-180 range It is best to do this with the engine warmed up. I never really see them vary more than 5-10 psi between cylinders and if you have one that is reading distinctly lower than I would look into that. A leakdown tester would definately help you isolate where the issue is. those pics of the plugs didnt look bad at all and shouldnt be the source of your problems. Try another set to rule them out if you havent already.
  3. #3 Re: PCV problems-Related to I/C
    TDCRacing
    Guest
    Quote Originally Posted by Trannyman95 View Post
    sure thing. Plugs arent bad? Really? I figured if they werent white that it wasent good. Of coarse if there Bright white then your lean but you get what im saying. Ill post up the results
  4. #4 Re: PCV problems-Related to I/C
    Fort Wayne, IN
    Some discoloration is normal, yours look more tan than they should be because of oil usage. If they were really bad you would be able to pic off the buildup with a pic or small screwdriver.
  5. #5 Re: PCV problems-Related to I/C
    St Louis MO
    Just want to let you guys know, putting a breather on your vc will cost you fuel because you MUST adjust your tune.
    I had what I thought was a belt squeak/squeal yesterday, while driving around town. All of this talk about blocked or restricted PCV's, has me paranoid...bass turds... Anyway today I threw on a Caspers breather, just in case it was PCV related It crapped on my fuel trims in the idle and cruise range big time. I'm seeing as high as 16.4 on hard decel and 10.9 at idle. On excelleration the trims are near what they were without the breather.
    I have a long trip today and am going to put the oil cap back on, but take the breather along with me. I need to somehow determine if the noise was PCV related or not. The squeal is very intermittant and doesn't allow the typical test of removing the oil cap to see if the noise goes away.
    2010 Camaro SS LS3
  6. #6 Re: PCV problems-Related to I/C
    St Louis MO
    I aasume PCV squeal is the built up gases needing to escape. I've already test the fresh air passage from the TB to the crankcase. Is there any reason why you couldn't theave the fresh air with PCV in the blower in tact and just mount a second PCV in the oil cap so excess presure could vent out, and therefore not have the fuel trim issues from having unmetered air from a breather?
    2010 Camaro SS LS3
  7. #7 Re: PCV problems-Related to I/C
    TDCRacing
    Guest
    Quote Originally Posted by IndeedSS View Post
    When you say your tune needs to be adjusted im assuming a maf tune or VE tune or what ever your preference is correct?
  8. #8 Re: PCV problems-Related to I/C
    St Louis MO
    Quote Originally Posted by TDCRacing View Post
    Both.
    Weird I put the cap back on, drove 250 miles yesterday and not squeaks or squeals. The fuel trims quickly returned to where they originally were.
    no........the squeal is from air trying to enter the crankcase because of the vacuum pulled through the manifold.
    That's what Dave said in his write-up too. So the potential oil leaking is not from gaskets blowing out but from being sucked in?
    2010 Camaro SS LS3
  1. ICM Problems??
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2009, 12:53 AM
  2. Before I have problems...
    By Keet04GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2008, 08:22 AM
  3. cam problems
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-05-2008, 06:59 PM
  4. Many problems/ Please help
    By Vurelis in forum General Tech Discussion
    Last Post: 06-15-2008, 03:45 PM
  5. 3k stall problem, is it tuning related?
    By Biggie in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2008, 06:29 PM
