Thread: PCV problems-Related to I/C
Results 1 to 20 of 27
Guest PCV problems-Related to I/C 08-27-2008, 11:48 PM
VinnieGTP Re: PCV problems-Related to... 08-28-2008, 12:02 AM
Guest Re: PCV problems-Related to... 08-28-2008, 12:08 AM
Street Wolf Re: PCV problems-Related to... 08-28-2008, 12:06 AM
VinnieGTP Re: PCV problems-Related to... 08-28-2008, 12:11 AM
Guest Re: PCV problems-Related to... 08-28-2008, 09:44 AM
IndeedSS Re: PCV problems-Related to... 08-28-2008, 10:11 AM
Guest Re: PCV problems-Related to... 08-28-2008, 10:14 AM
IndeedSS Re: PCV problems-Related to... 08-28-2008, 10:39 AM
Guest Re: PCV problems-Related to... 08-28-2008, 10:46 AM
IndeedSS Re: PCV problems-Related to... 08-28-2008, 11:12 AM
Street Wolf Re: PCV problems-Related to... 08-28-2008, 12:21 AM
Trannyman95 Re: PCV problems-Related to... 08-28-2008, 01:49 AM
Guest Re: PCV problems-Related to... 08-28-2008, 08:47 AM
Reptile Re: PCV problems-Related to... 08-28-2008, 02:53 AM
IndeedSS Re: PCV problems-Related to... 08-28-2008, 07:51 AM
Guest Re: PCV problems-Related to... 08-28-2008, 08:37 AM
Guest Re: PCV problems-Related to... 08-28-2008, 08:48 AM
Reptile Re: PCV problems-Related to... 08-30-2008, 10:05 PM
Guest Re: PCV problems-Related to... 08-31-2008, 01:07 AM
  1. #1 Re: PCV problems-Related to I/C
    TDCRacing
    Guest
    Quote Originally Posted by VinnieGTP View Post
    Oil still comes through there though if you don't do one of those. Either way will fix it.
    While you're in there, plug the 2 coolant holes. If you cant tap and plug them just sand down a couple dimes and RTV them in there. The dime's diameter is just a tad too big to fit without sanding.
    So just to clarify your saying I need to do the LIM mod and Dave is saying that I have plenty of flow becuase of the breather and shouldnt? The passage that I would cut in the LIM would be for air though. So how is that going to stop the oil if I already have enough flow from the breather? Just trying to get to the problem of this crap. Not trying to question anybody's judgement or anything. So don't take it the wrong way or anything. Trust me I appreciate everyones help and would not have contacted the people i did if i didnt think they could help.
  2. #2 Re: PCV problems-Related to I/C
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Just curious if you tried the cylinder balance test built in to the HPTuners? The cyclinders should be within a couple % of each other.
    Your plugs don't look that dark to me. But in the fist picture i see black on the top part of the insulator. That stuff could cause arcing.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: PCV problems-Related to I/C
    TDCRacing
    Guest
    no cant for the life of me find out how. I get to the point where it says IAC not ready or something like that. I think i even tried comanding the IAC on but it wouldnt let me. What exactly is this doing anyway? Care to explain how?
  4. #4 Re: PCV problems-Related to I/C
    St Louis MO
    I have a write-up somewhere. let me see if I can find it.
    LOL you are going to shoot yourself.
    http://www.grandprixforums.net/f65/j...ions-2020.html
    2010 Camaro SS LS3
  5. #5 Re: PCV problems-Related to I/C
    TDCRacing
    Guest
    Wow...That seems so long ago lol...I knew the title sounded fimiliar..Thanks BTW...
  6. #6 Re: PCV problems-Related to I/C
    St Louis MO
    No problem
    2010 Camaro SS LS3
  7. #7 Re: PCV problems-Related to I/C
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Do a compression test. #s greatly vary but are often in the 155-180 range It is best to do this with the engine warmed up. I never really see them vary more than 5-10 psi between cylinders and if you have one that is reading distinctly lower than I would look into that. A leakdown tester would definately help you isolate where the issue is. those pics of the plugs didnt look bad at all and shouldnt be the source of your problems. Try another set to rule them out if you havent already.
  1. ICM Problems??
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2009, 12:53 AM
  2. Before I have problems...
    By Keet04GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2008, 08:22 AM
  3. cam problems
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-05-2008, 06:59 PM
  4. Many problems/ Please help
    By Vurelis in forum General Tech Discussion
    Last Post: 06-15-2008, 03:45 PM
  5. 3k stall problem, is it tuning related?
    By Biggie in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2008, 06:29 PM
