Wow...That seems so long ago lol...I knew the title sounded fimiliar..Thanks BTW...
Do a compression test. #s greatly vary but are often in the 155-180 range It is best to do this with the engine warmed up. I never really see them vary more than 5-10 psi between cylinders and if you have one that is reading distinctly lower than I would look into that. A leakdown tester would definately help you isolate where the issue is. those pics of the plugs didnt look bad at all and shouldnt be the source of your problems. Try another set to rule them out if you havent already.
Some discoloration is normal, yours look more tan than they should be because of oil usage. If they were really bad you would be able to pic off the buildup with a pic or small screwdriver.
Just want to let you guys know, putting a breather on your vc will cost you fuel because you MUST adjust your tune.
I had what I thought was a belt squeak/squeal yesterday, while driving around town. All of this talk about blocked or restricted PCV's, has me paranoid...bass turds...Anyway today I threw on a Caspers breather, just in case it was PCV related
It crapped on my fuel trims in the idle and cruise range big time. I'm seeing as high as 16.4 on hard decel and 10.9 at idle. On excelleration the trims are near what they were without the breather.
I have a long trip today and am going to put the oil cap back on, but take the breather along with me. I need to somehow determine if the noise was PCV related or not. The squeal is very intermittant and doesn't allow the typical test of removing the oil cap to see if the noise goes away.
I aasume PCV squeal is the built up gases needing to escape. I've already test the fresh air passage from the TB to the crankcase. Is there any reason why you couldn't theave the fresh air with PCV in the blower in tact and just mount a second PCV in the oil cap so excess presure could vent out, and therefore not have the fuel trim issues from having unmetered air from a breather?
