Thread: Turn Signal on Solid
Results 1 to 10 of 10
coolken84 Turn Signal on Solid 08-19-2008, 01:16 PM
coolken84 Re: Turn Signal on Solid 08-19-2008, 05:07 PM
BackInBlack Re: Turn Signal on Solid 08-19-2008, 06:42 PM
BADAZGTP Re: Turn Signal on Solid 08-19-2008, 07:56 PM
justwhisen Re: Turn Signal on Solid 08-20-2008, 12:23 AM
UR LOSN Re: Turn Signal on Solid 08-20-2008, 05:00 AM
BackInBlack Re: Turn Signal on Solid 08-20-2008, 11:27 AM
Egleone6 Re: Turn Signal on Solid 08-26-2008, 04:40 PM
gtpinsc Re: Turn Signal on Solid 08-26-2008, 06:53 PM
99prixgt Re: Turn Signal on Solid 08-31-2008, 01:39 AM
  1. #1 Turn Signal on Solid
    SE Level Member coolken84's Avatar
    Apr 2008
    This is strange, This morning when I started my 01 GP up the right turn signal light on my dash & hud was lit solid - checked the signal stalk & it was not switched to the right. Left turn signal works correctly and stays off when turned off. Unplugged the bulb from the right front headlight housing & the light went dim on the dash, but the rear turn signal light is still lit. I can hear a faint buzzing sound coming from under the dash below the steering column when the lights are lit. Only thing I've done recently in that area is removing the ignition switch interlock solenoid to cure the sticking key syndrome, and that was just unplugging it & removing it. Any Ideas??
  2. #2 Re: Turn Signal on Solid
    Apr 2008
    Ignore this post...It went back to normal on it's own...Strange!
  3. #3 Re: Turn Signal on Solid
    GT Level Member BackInBlack's Avatar
    Vermont
    I suspect that you may have a failing tun signal switch assembly...
    The GPs are long gone...
  4. #4 Re: Turn Signal on Solid
    Apr 2008
    Chillin at the Beach , VA
    Flasher relay could be on its way out.
  5. #5 Re: Turn Signal on Solid
    Jul 2008
    Poteau Oklahoma
    agree with badaz^^ its cheaper to replace also.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  6. #6 Re: Turn Signal on Solid
    I live here. UR LOSN's Avatar
    Rockford, IL
    flasher.....or condensation in the connector......
  7. #7 Re: Turn Signal on Solid
    Vermont
    Unless the turn signal switch is engaged, the flasher module does nothing. I doubt it's the flasher module...
  8. #8 Re: Turn Signal on Solid
    GT Level Member Egleone6's Avatar
    Springfield, Illinois, United States
    Did you check the blinker fluide, worked for me.
    If my pics are not working, please email me, I may have moved the pics on a different page on Photobucket. Thanks
  9. #9 Re: Turn Signal on Solid
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by Egleone6 View Post
  10. #10 Re: Turn Signal on Solid
    Jersey
    I had the same problem with my 95 Riviera, after the blinker stayin on constant it just stopped working all together same buzzing sound, i replaced the turn signal switch and still didnt fix it all relays and fuses were good. I would drive everyday without a turn signal at all. Never figured it out...
    16' wrx sti- stock
  1. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  2. front turn signals
    By miller in forum Visual/Body Modifications
    Last Post: 12-24-2008, 11:24 PM
  3. wiper/turn signal switch
    By GOINDEF in forum General Tech Discussion
    Last Post: 05-13-2008, 07:52 PM
  4. Tranny sounds turn out to be far worst..
    By evlprx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-22-2008, 08:55 AM
  5. Exterior Fog/Turn Signal and Interior Window Controls
    By POLECAT2007 in forum Visual/Body Modifications
    Last Post: 02-16-2008, 04:31 PM
