Thread: Subframe mounts
Results 1 to 20 of 36
  1. #1 Subframe mounts
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    I've disscussed this topic so many times but it's been a good while since I did my GS and now it's time for the LS. I remember the rear being easy to remove but the front being much more difficult. I know most of you have a GTP and I have a GS but they both are W-bodies so they should have the same process of removing/installing.
    So what would be the easiest way to remove these mounts specifically the front? Im sure my impact will loosen the bolt and some tension off the mount but it won't allow the mount to fall free on it's own.
    Rear should be a breeze beings though they should slide right out Once the rear of the subframe/cradle is dropped/lowered but what would be the best process for removing the front And getting those mounts outs?
    Any pics would help also.
    Thanks......
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: Subframe mounts
    Jul 2012
    North Philly
    WOW, nobody has done their subframe mounts yet???
  3. #3 Re: Subframe mounts
    Banned
    I had mine done at a shop for $180 labor. All I know is they did not drop the subframe completely. Use GM mounts!
  4. #4 Re: Subframe mounts
    Jul 2012
    North Philly
    Quote Originally Posted by ebk231 View Post
    Damn, $180 ain't bad. I mean I would knock it out for somebody for that price or even cheaper but for a shop....they were being generous. Need more shops like them lol
  5. #5 Re: Subframe mounts
    gardner,mass
    Ide just drop the subframe. Take a 4x4 and use ratchet straps to hold up the engine and remove the lower nuts for the engine and trans mounts and remove the bolts holding in the steering rack and it will drop right out. There are also a few clips holding in the wire harness and maby the power steering lines. You can also clean up the subframe while its out. Probly take an hour tops to remove it.
    Oh yea forgot to mention the ball joints.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #6 Re: Subframe mounts
    why drop the whole sub frame? lower the back, change them, then lower the front and change them.....sounds easy enough in my head.......
  7. #7 Re: Subframe mounts
    Or this which would make it even easier... I've lowered the subframe enough and never had a issue with the bearings just falling out.
    04 Comp G.
  8. #8 Re: Subframe mounts
    Jul 2012
    North Philly
    Wait, so when you lowered the fwd end of the subframe the mounts just fell out? No PB blaster or WD-40? I know the rear comes out pretty easy but the front is a pain
  9. #9 Re: Subframe mounts
    Jul 2012
    North Philly
    This is definitely what I would do and have always did. I just do one end at a time. my only issue is getting the front mounts to come out. other than sitting here picking at these mounts/rubber theres gotta be an easier way
  10. #10 Re: Subframe mounts
    gardner,mass
    Quote Originally Posted by Dee23 View Post
    Im thinking drop the cradle and use a big socket to knock it out.
  11. #11 Re: Subframe mounts
    Jul 2012
    North Philly
    Quote Originally Posted by Ginseng View Post
    A big Socket or a big CHISEL? LOL. After 14yrs those mounts are pretty comfortable in their spot
  12. #12 Re: Subframe mounts
    K.i.s.s. Just like you would if your were doing a cam install from the fender area..drop one side of the subframe slightly..just enough where the bolts are still threaded in and the subframe is still holding on..stick a jack as well as jack stands underneath to prevent it from falling out..then with a jack underneath the otherside jack that side of the subframe up then completely remove the 2 bolts..replace the bushings..jack it up thread the bolts in.leave the jack and then vice versa and do it for the other side? Does that make sense?
    04 Comp G.
  13. #13 Re: Subframe mounts
    Jul 2012
    North Philly
    Yeah, I mean I know how to drop the cradle/subframe, its just getting the rubber out of the mount bore/housing
  14. #14 Re: Subframe mounts
    Yup. Mines just fell out no need for pb blaster or WD40 I thought it was a bit to easy.. But sometimes you can't question easy lol.
    04 Comp G.
  15. #15 Re: Subframe mounts
    Jul 2012
    North Philly
    Hmmmmmmmmmm, front or the rear?
  16. #16 Re: Subframe mounts
    Jul 2012
    North Philly
    Ok Im convinced, so the loosening of my Impact gun alone should get these mounts out...hopefully? I mean im prepared for some work of course
  17. #17 Re: Subframe mounts
    when i had my tranny swapped the mounts pretty much fell out of the frame. it wont take much to get them out.
  18. #18 Re: Subframe mounts
    Jul 2012
    North Philly
    You guys hyping me up lol. About a year ago I did my GS mounts and I had to use a air Hammer, like really. So on my LS im procrastinating about doing these mounts bc if I get in the middle of this job but cant get the mounts and or all the rubber out then not only will the new mounts fit properly but that'll be a problem bc my wife drives this car to work every morning.
    Hmmmmmmmmmmmm
  19. #19 Re: Subframe mounts
    all 4 fell out of mine. there was nothing holding them in at all. free floating if you will.
  20. #20 Re: Subframe mounts
    This.
    04 Comp G.
  1. Subframe/rack
    By cavell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-16-2013, 06:28 AM
  2. Lower mounts & mounts spacers
    By iRideGTP in forum General Tech Discussion
    Last Post: 08-02-2012, 04:13 PM
  3. Subframe Bushings
    By ls1camino in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2012, 08:14 AM
  4. Do you have to drop the subframe?
    By pur3vil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2011, 01:40 PM
  5. subframe bushings??
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2011, 09:54 PM
