I've disscussed this topic so many times but it's been a good while since I did my GS and now it's time for the LS. I remember the rear being easy to remove but the front being much more difficult. I know most of you have a GTP and I have a GS but they both are W-bodies so they should have the same process of removing/installing.
So what would be the easiest way to remove these mounts specifically the front? Im sure my impact will loosen the bolt and some tension off the mount but it won't allow the mount to fall free on it's own.
Rear should be a breeze beings though they should slide right out Once the rear of the subframe/cradle is dropped/lowered but what would be the best process for removing the front And getting those mounts outs?
Any pics would help also.
Thanks......
