Thread: Helicoil the rear brake caliper hose hole?
Results 1 to 20 of 25
  1. #1 Helicoil the rear brake caliper hose hole?
    Oct 2011
    Toledo, OH
    Anyone ever do it? Had 2 brand new rear calipers strip out before the new copper washer deformed. I've never helicoiled anything at all, but that is likely my only choice if I want to drive my car again, or else buy new calipers for the 2nd time this weekend.
    7"
  2. #2 Re: Helicoil the rear brake caliper hose hole?
    SWPA
    I don't think brakes is one of those things I would go an helicoil.
  3. #3 Re: Helicoil the rear brake caliper hose hole?
    Jan 2014
    AR
    I agree.
  4. #4 Re: Helicoil the rear brake caliper hose hole?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    I agree that's a lot of pressure. If I had to I would re-thread them.
  5. #5 Re: Helicoil the rear brake caliper hose hole?
    Do you have a warranty on them maybe just exchange them?
    04 Comp G.
  6. #6 Re: Helicoil the rear brake caliper hose hole?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by lewis1952 View Post
    That would involve finding a bigger banjo bolt, and bigger brake lines. Not sure about the logistics of that, probably easier to get new calipers.
    I emailed them and let them know the situation but I assume I'm SOL because it's not a defect even though I followed the included warning to torque them to my manufacturers specs.
    Looks like helicoil isn't the best idea. Time-serts are, but that kit is $86, worth it for an engine block, not for a $100 set of calipers.
    7"
  7. #7 Re: Helicoil the rear brake caliper hose hole?
    Jan 2014
    AR
    You might try stacking copper washers, in case you're bottoming out threads. Or perhaps just use one thinner washer so it would deform more easily. I've run into lines on all-aftermarket stuff that went both those ways.
  8. #8 Re: Helicoil the rear brake caliper hose hole?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by idrivejunk View Post
    There are still a good amount of threads in the caliper so I know I wasn't bottoming out. The washers they included were bigger dia, but same thickness as the one that came off. The calipers aren't aftermarket per se, they are just powder coated re-mans.
    7"
  9. #9 Re: Helicoil the rear brake caliper hose hole?
    Worse case.. Use yours as a core and grab a set from the parts store..
    04 Comp G.
  10. #10 Re: Helicoil the rear brake caliper hose hole?
    Oct 2011
    Toledo, OH
    Yeah but what is up with local store prices recently? $86 each plus $30 core at Autozone, when the exact same ones are on RA for $106/pair shipped, core included.
    7"
  11. #11 Re: Helicoil the rear brake caliper hose hole?
    SWPA
    Buy online, use discount codes, and pick up in store....
  12. #12 Re: Helicoil the rear brake caliper hose hole?
    This.. Use a $30 off $75
    Place 2 orders..
    Pick up then exchange your cores.. You'll be surprised how stupid cheap they'll come out to be
    04 Comp G.
  13. #13 Re: Helicoil the rear brake caliper hose hole?
    SWPA
    In the last year alone I have probably saved close to $1000 from doing it that way.
    There is also no reason to be worried about the core charge because you get it back anyway.
  14. #14 Re: Helicoil the rear brake caliper hose hole?
    Same here.. That's my method. Also helps that advance is literally a walk across the street do it's a no brainer.. No need for rockauto for me unless it's something I can't find there.
    04 Comp G.
  15. #15 Re: Helicoil the rear brake caliper hose hole?
    SWPA
    Advance guys know me anyway, but they actually love that I do it that way. I walk in, hand them my order number and walk out in a matter of minutes.... unless I sit around and BS with them.
  16. #16 Re: Helicoil the rear brake caliper hose hole?
    Antioch, IL
    I dont know where you shop calipers for me they are $27.99 with core returned without any coupons. If they stripped I would march right back in and get another one.
    2009 Challenger SRT8
    Expert at being gay.
  17. #17 Re: Helicoil the rear brake caliper hose hole?
    Same here and I get the usual working on that GP of yours huh.
    04 Comp G.
  18. #18 Re: Helicoil the rear brake caliper hose hole?
    SWPA
    Quote Originally Posted by ITHURTZ View Post
    Price difference between a 97-03 and 04-08 GP on a rear caliper is around $40...
  19. #19 Re: Helicoil the rear brake caliper hose hole?
    Antioch, IL
    48.99 with return without coupon.still cheap as hell
  20. #20 Re: Helicoil the rear brake caliper hose hole?
    SWPA
    Where is that?
    Believe it or not prices can vary based just on ZIP code too.
  1. Brake Caliper
    By boomzdaddy in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2013, 05:20 PM
  2. Putting the parking brake cable on the rear caliper
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2013, 03:32 PM
  3. Rear Brake Hose Oddity
    By 03dodgediesel in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2013, 06:51 AM
  4. A/C compressor hose has a hole in it...
    By selym17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-09-2012, 06:11 AM
  5. Balance shaft rear oil hole....
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2011, 04:49 PM
