Thread: Subframe mounts
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Subframe mounts
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Ok Im convinced, so the loosening of my Impact gun alone should get these mounts out...hopefully? I mean im prepared for some work of course
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #22 Re: Subframe mounts
    the mounts just sit in the frame, the bolt just makes a rubber and steel sandwich.
  3. #23 Re: Subframe mounts
    Get to it! Hurry before Monday comes and Bill sees this!
    04 Comp G.
  4. #24 Re: Subframe mounts
    lets bully him now red lol do it!!!!!!
  5. #25 Re: Subframe mounts
    Jul 2012
    North Philly
    , Im gone
  6. #26 Re: Subframe mounts
    Jul 2012
    North Philly
    thought we were brothers, LOL
  7. #27 Re: Subframe mounts
    lol
  8. #28 Re: Subframe mounts
    You had 2 days to get it done.. Since you made this thread. Get on it now now now! Stop lollygagging around!
    04 Comp G.
  9. #29 Re: Subframe mounts
    gardner,mass
    I think ima order some liquid polly and use that to make some.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  10. #30 Re: Subframe mounts
    Anyone care to post the part # for the bushing so I don't have to go searching for them.
    04 Comp G.
  11. #31 Re: Subframe mounts
    Jul 2012
    North Philly
    Subframe mounts:
    rear upper- GM 10249731
    rear lower- GM 10248771
    DorMan Rear: 924-045
    Front:
    GM 10023412
    DorMan 924-006
    I once used the front Dorman bc at the time it was cheaper and I could only find the front mounts in Dorman brand. Good luck on finding the Rear in any other brand other than GM. So at the time going Dorman up front and GM in the rear saved me some change. but as you can see via part# they now have the Dorman mounts for the rear and front(well I just found the rear after years of searching). but what I have also found out is that GM now sells front and rear mounts for around the same price as the Dorman give or take $10 which is mainly tax. So I now have new original GM mounts for the LS which I just paid a fraction of what I paid for my GM mounts on the GS just under 2yrs ago. Go for the GM, hopefully your local dealer has them and are selling them at the same price as I got mine. RockAuto only has the front(weird), Dorman site only as the front as most sites(weird and dumb), but the almighty AMAZON has both front and rear...just type in the dorman part# GM part# may work also
  12. #32 Re: Subframe mounts
    I'd do it the same way I did it on Bonne..
    Put your jack under the center of the front subframe and unbolt both sides.. lower a bit while watching things from above/below. Slow is your friend.
    Reach up.. put new in .. bolt back up.
  13. #33 Re: Subframe mounts
    Jul 2012
    North Philly
    Yeah it was easy, lol but you guys had made it seem like there was no possibility of the two front passenger and driver side mounts couldn't have been seized in there. I was just worried of what I was going to use to get them out.
    You never know, these W-bodies like to surprise you sometimes......LOL
  14. #34 Re: Subframe mounts
    Rear mounts are typically pressed in from the top. Fronts on these are usually much easier, especially the top piece.
  15. #35 Re: Subframe mounts
    Jul 2012
    North Philly
    I've just been schooled by bill boost, No worries i'll run with it....LOL
  16. #36 Re: Subframe mounts
    Jul 2012
    North Philly
    I admitted that the subframe mounts were easy but the most fwd mounts near the radiator support are killing me. The metal lip that im pointing at circling this new mount is the same lip on this old mount that wont break loose to allow me to yank this mount out. I've used PB blaster and every tool that I have. Ive been biting at the rubber for a while now but the metal bore sleeve is being stubborn too.
    Any ideas before Monday gets here, sucks bc majority of the mount is damaged so driving the car this way is not safe
    [IMG][/IMG]
    [IMG][/IMG]
  1. Subframe/rack
    By cavell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-16-2013, 06:28 AM
  2. Lower mounts & mounts spacers
    By iRideGTP in forum General Tech Discussion
    Last Post: 08-02-2012, 04:13 PM
  3. Subframe Bushings
    By ls1camino in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2012, 08:14 AM
  4. Do you have to drop the subframe?
    By pur3vil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2011, 01:40 PM
  5. subframe bushings??
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2011, 09:54 PM
