Thread: Subframe mounts
Results 1 to 20 of 36
  1. #1 Re: Subframe mounts
    K.i.s.s. Just like you would if your were doing a cam install from the fender area..drop one side of the subframe slightly..just enough where the bolts are still threaded in and the subframe is still holding on..stick a jack as well as jack stands underneath to prevent it from falling out..then with a jack underneath the otherside jack that side of the subframe up then completely remove the 2 bolts..replace the bushings..jack it up thread the bolts in.leave the jack and then vice versa and do it for the other side? Does that make sense?
    04 Comp G.
  2. #2 Re: Subframe mounts
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Yeah, I mean I know how to drop the cradle/subframe, its just getting the rubber out of the mount bore/housing
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  1. Subframe/rack
    By cavell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-16-2013, 06:28 AM
  2. Lower mounts & mounts spacers
    By iRideGTP in forum General Tech Discussion
    Last Post: 08-02-2012, 04:13 PM
  3. Subframe Bushings
    By ls1camino in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2012, 08:14 AM
  4. Do you have to drop the subframe?
    By pur3vil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2011, 01:40 PM
  5. subframe bushings??
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2011, 09:54 PM
