Alright so I attempted to swap out my stock front brakes for the 06 impala brakes today. Got everything installed/bolted back up. Didn't open up any of the rear lines, just the fronts. Bled both front calipers probably 10 times, always starting with the passenger side first. Didn't feel any better, still went to floor. Noticed there was a bleeder screw on the abs pack, haynes manual said to bleed that first and then do the calipers. So did the same bleeding method I did for the calipers ONLY on the front bleeder screw for the front brakes. Then I did the front calipers again. No difference. Tried a gravity bleed on both fronts. (just leaving the bleeders open and letting it drip). Then rebled each caliper. No difference. Tried bleeding several more times. No difference, pedal still goes to floor. What could be the damn issue with this??? I have to call out of work tomorrow because of this hold up. Any help would be appreciated, thanks!!
This is on a 98 Regal. Yes I realize this isn't a GP, but same system.
