Thread: Won't start after cam install
Page 16 of 23 FirstFirst ... 61415161718 ... LastLast
Results 301 to 320 of 448
  1. #301 Re: Won't start after cam install
    May 2008
    Schuyler, NE
    Quote Originally Posted by TheOtherNick View Post
    If one tooth would do that how do gt's run with a degree of cam advance from the factory>?
    Because if you are off even just one tooth, it's way more than the 2* difference the l36/26 timing set change it to.
  2. #302 Re: Won't start after cam install
    Charles City, IA
    A tooth on the doubler roller is 2*.
    SMGPFC Two Nipple General
  3. #303 Re: Won't start after cam install
    This really doesn't make sense to me. Which is why I am asking about the crank keyway. I've seen it get funky on others. Unlike the HB key, the crank key would cause that exact problem because then things wouldn't be timed properly.
    One of the things I love about the 3.8 is that it's nearly the worlds simplest motor. Set balance shaft to cam, set the cam key to about 4 oclock, crank key to about 2 oclock and presto, your nearly timed right. Then the HB and sensors take care of the rest. Crank goes around twice and the cam once. So by lining up the dot you put the intake lobe in the right place. Degreeing is a good idea and it has a lot of merit. However it would be off a slight amount, not enough to bend rods like pretzels.
  4. #304 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Maybe Aaron is right. Maybe the gas hydrolocked it. I was getting a metallic sound when I tried to turn it over with the balancer on wrong. It also felt like it was binding (even with the spark plugs out). Maybe that was enough force to break/bend them. Because when my motor turns over, my pistons and valves are doing what they should be doing.
  5. #305 Re: Won't start after cam install
    Or maybe stuck valves? I go to school for aircraft maintenance engineering, and I've seen first hand what sticking valves can do to an engine's valvetrain. I guess it's worth a try to pull a few springs off and check? It's just weird that it bent 9 out of 12 pushrods.
  6. #306 Re: Won't start after cam install
    Wasn't stuck valves.
    It wasn't hydrolocking. Hydrolocking is the piston trying to compress liquid in the cylinder when the valves are closed. Aka ..no pressure on the rods or rockers.
    No.. this is .. piston hit the effin valve and the pushrod bent like a pretzel. Which is why I'm saying.
    PULL THE HEADS
    and huge witing because no one seems to be listening to what I'm saying anymore. So it's dickhead mode to get you guys to listen up.
  7. #307 Re: Won't start after cam install
    PULL THE HEADS
    I understand what you're saying. I just don't understand how the pistons and the valves could hit. The timing marks are fine and I confirmed it by turning the motor over with the lifters in. How is it possible?
  8. #308 Re: Won't start after cam install
    Remember the part where I questioned the keyways? That's the only thing that makes any sense.
    Hydrolocking is valves closed. So it's piston rods that might get hurt or bearings.
    The only way pushrods get bent like that is to smack the valves off the pistons.
    Your pics being on the timing marks make no sense as to why this happened, so I'm thinking about how it happened on one keyway, maybe it happened on another when you pulled it back apart. Because something doesn't make any sense at all if your marks are on the money. So if you pulled the front cover again and it's all perfectly straight up, then I'm at a total loss and would love to learn something new. Just not at your expense. Ya know.
  9. #309 Re: Won't start after cam install
    May 2008
    Schuyler, NE
    I'm not going to go back and dig through everything, but this is just a stock timing chain, right?
    It depends on which sprocket is off, how much timing is changed.
  10. #310 Re: Won't start after cam install
    Who knows... Maybe the whole harmonic balancer/crank key thing messed up the position of the crank sprocket. However, after removing the sprockets, I inspected them, and made sure the keyways were in good shape. Me and my dad re-assembled it, and made SURE the keys lined up. From what I see from turning the motor over, and watching the lifters and firing order, the engine is timed right.
  11. #311 Re: Won't start after cam install
    The balancer can't change the timing. That chain is the one and only thing that controls what happens to valve movement. That's what has me stumped
  12. #312 Re: Won't start after cam install
    GT Level Member RegalGS98s's Avatar
    NJ
    I don't remember, but when the harmonic balancer was on wrong, did the key come off the crank sprocket? So the cam didn't turn and the valves stayed in position so the pistons made contact? Like Bill said, pull the heads, or at least use an inspection camera of sorts through the spark plug hole.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  13. #313 Re: Won't start after cam install
    Quote Originally Posted by RegalGS98s View Post
    No the key stayed in the sprocket, from what I saw. I'll look at my car tonight. Going home in 20 minutes.
  14. #314 Re: Won't start after cam install
    Pulled the head with the most pushrod damage...
    I knew it. The valves DID NOT touch the pistons. It was timed properly the entire time. This proves that having your balancer on incorrectly (awful ignition timing) can damage your pushrods.
  15. #315 Re: Won't start after cam install
    better safe than sorry, glad its all intact, lets hope the second time around works out well.
  16. #316 Re: Won't start after cam install
    Grand Rapids, MI
    well this is great news!
  17. #317 Re: Won't start after cam install
    did you use head bolts?
    and buy L36 head gaskets, they're cheaper than the L67 ones.
  18. #318 Re: Won't start after cam install
    I did use head bolts. I just went and bought a new L36 head gasket and new bolts, as well as a new LIM gasket. Gonna start reassembling!
  19. #319 Re: Won't start after cam install
    ****! The guy gave me a right head gasket instead of a left one. Ughhhhhh. Why didn't I look? My god.
  20. #320 Re: Won't start after cam install
    store's still open though right?
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
