Thread: Won't start after cam install
Page 15 of 23 FirstFirst ... 51314151617 ... LastLast
Results 281 to 300 of 448
  1. #281 Re: Won't start after cam install
    Nov 2010
    Atlanta Ga
    Didnt think about that, I dont know enough about aftermarket rockers to comment on that one!
  2. #282 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    If the cam got f*cked, wouldn't the lifters look like hell too? The rollers on them look brand new. I'll pull the heads tonight and have a look. I REEEEAAALLLY don't want to have to pull the cam out again.
    P.S. I never changed the rockers. They are stock.
  3. #283 Re: Won't start after cam install
    i'd spin the engine so cly 1 is tdc and see where the cam lobes are, im pretty sure they should both be in the closed position., if you drop back in 2 lifters for cly 1, you should be able to tell where the lobes of the cam are.
    any way you look at it something is way off some how some where. i've never seen every push rod bent or broken.
    it would be a trip if you got a boat engine cam shipped to you, most boat engines run backwards.
  4. #284 Re: Won't start after cam install
    Yea I'll try that procedure with the lifters. I bought this cam off 03impala9c1. He's a very well respected member on many forums.
  5. #285 Re: Won't start after cam install
    May 2008
    Schuyler, NE
    Are you sure that your timing marks are lined up?....because from that picture you posted, it looks to me like they are a tooth off.
  6. #286 Re: Won't start after cam install
    They are. The angle of the camera makes it look like it's off. But even still, a tooth off wouldn't cause this mayhem.
  7. #287 Re: Won't start after cam install
    May 2008
    Schuyler, NE
    I'm pretty sure it can.....and has in the past.
  8. #288 Re: Won't start after cam install
    I'm 99.99&#37; sure they are lined up perfectly. Very very very close. The picture looks fine to me?
  9. #289 Re: Won't start after cam install
    Nov 2010
    Atlanta Ga
    I dont think a tooth would do that. If you spin the motor with all of the push rods out does it spin freely? Maybe not a good test if the valves are bent. Befor you go back together with the heads i would borrow a degree wheel and confirm the cam opening/closing times match up with the vs cam specs. Ill look and see if i still have my spec card. Aside from the bellhousing bolt between the eng/trans its really easy to pull one of these motors. Would make removing heads/cam/and oil pan (to check for any metal pieces) a lot easier.
  10. #290 Re: Won't start after cam install
    Nov 2010
    Atlanta Ga
    A quick leak down test would tell u if there is damage to the valves. Would be easier than pulling the heads. Im pretty sure there is going to be valve damage with bent rods like that but u never know.
  11. #291 Re: Won't start after cam install
    Charles City, IA
    If one tooth would do that how do gt's run with a degree of cam advance from the factory>?
    SMGPFC Two Nipple General
  12. #292 Re: Won't start after cam install
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Explain how that's possible on our motors please. Because I'm not aware of it being possible.
    Yeah...don't know what the hell I was thinking. Now I feel like a dumb ass.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  13. #293 Re: Won't start after cam install
    any chance those roller style lifters are taller than a stock lifter?
  14. #294 Re: Won't start after cam install
    Charles City, IA
    stock lifters are roller.
  15. #295 Re: Won't start after cam install
    I took all the spark plugs out and turned the motor by hand with the lifters installed. The piston/cam timing is correct on #1 cylinder. The lifters stay down on compression stroke, the intake lifter comes up on intake stroke, and the exhaust lifter comes up on exhaust stroke. I looked in the valleys in the heads, and the valve stems look fine (from what I can see).
  16. #296 Re: Won't start after cam install
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Maybe from repeated trying to start the engine you had so much fuel in there it hydrolocked and bent the pushrods? About the only thing I could think of if the timing was correct. Other questions are what Springs and what rockers are you using again?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  17. #297 Re: Won't start after cam install
    Quote Originally Posted by 01gpgt01 View Post
    Hmmm. Yea that is possible. I'm using G8 springs/retainers and stock rockers.
  18. #298 Re: Won't start after cam install
    My firing order is also correct. I'm soaking my lifters in oil overnight. Tomorrow, I will assemble the valve train and do a compression test on each cylinder, by turning the motor over by hand.
  19. #299 Re: Won't start after cam install
    Charles City, IA
    Just disable fuel and spark and crank it with the starter
  20. #300 Re: Won't start after cam install
    Quote Originally Posted by TheOtherNick View Post
    It has no oil. Is that fine? Also, is it fine to do with my LIM off?
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
