Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    The balancer can't change the timing. That chain is the one and only thing that controls what happens to valve movement. That's what has me stumped
  2. #2 Re: Won't start after cam install
    GT Level Member RegalGS98s's Avatar
    NJ
    I don't remember, but when the harmonic balancer was on wrong, did the key come off the crank sprocket? So the cam didn't turn and the valves stayed in position so the pistons made contact? Like Bill said, pull the heads, or at least use an inspection camera of sorts through the spark plug hole.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #3 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by RegalGS98s View Post
    No the key stayed in the sprocket, from what I saw. I'll look at my car tonight. Going home in 20 minutes.
  4. #4 Re: Won't start after cam install
    Pulled the head with the most pushrod damage...
    I knew it. The valves DID NOT touch the pistons. It was timed properly the entire time. This proves that having your balancer on incorrectly (awful ignition timing) can damage your pushrods.
  5. #5 Re: Won't start after cam install
    better safe than sorry, glad its all intact, lets hope the second time around works out well.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
