Thread: Won't start after cam install
Page 1 of 19 12311 ... LastLast
Results 1 to 20 of 448
  1. #1 Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I just got my motor put back in, got everything connected and hooked up, primed the oil pump, but when I go to start it, it just cranks, stutters and "coughs" when you stop cranking off. The cough noise sounds like it comes from the intake, but I'm not sure. Here's a video of it:
    http://i82.photobucket.com/albums/j2...3/01c4a061.mp4
    And
    http://i82.photobucket.com/albums/j2...3/8b0ccd9d.mp4
    I also need help locating where this line plugs into:
    Thanks guys!
  2. #2 Re: Won't start after cam install
    Never Never Land
    not sure if im right but i can see on the supercharger vaccum tree your missing a line. it might go there. not sure though.
  3. #3 Re: Won't start after cam install
    It does.
    Plug that line into the top of the blower and see how it runs after that...you've got a decent vac leak right there.
  4. #4 Re: Won't start after cam install
    GT Level Member Deviq's Avatar
    SE WI
    You can see the empty port on the tree it goes into in the second pic.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  5. #5 Re: Won't start after cam install
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    yea thats where mines goes. The middle line in the red circle.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  6. #6 Re: Won't start after cam install
    GT Level Member Tea Time's Avatar
    New Brunswick
    All of the above are right about the vacuum line, it runs ur HVAC , plug it into that tree on top the blower and hopefully blue is right about the non start, thats a nasty vacuum leak with it left unplugged.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  7. #7 Re: Won't start after cam install
    Thanks guys. I'll plug it in and give it a try tonight. I really hope that's the problem.
  8. #8 Re: Won't start after cam install
    it sounds like its back firing out the intake, have you double checked the plug wires firing order? 2 wires in the wrong place will mess you up good.
  9. #9 Re: Won't start after cam install
    I'll double check the spark plug wires tonight. I hope it's something simple. This is stressing me out.
  10. #10 Re: Won't start after cam install
    Charles City, IA
    Hook that back up, check plug wires, check icm ground under coil packs.
    SMGPFC Two Nipple General
  11. #11 Re: Won't start after cam install
    Car should still run with that disconnected.
    if the brake booster line was disconnected it wont.
  12. #12 Re: Won't start after cam install
    Never Never Land
    really cuz my camaro started with the brake booster line disconnected.
  13. #13 Re: Won't start after cam install
    So if it won't start with that line connected, and the spark plug wires are all hooked up properly, what should I look at?
  14. #14 Re: Won't start after cam install
    spray a little starting fluid in it and see if it's a fuel issue.
  15. #15 Re: Won't start after cam install
    how about take it one step at a time, do what we have suggested then trouble shoot from there.
  16. #16 Re: Won't start after cam install
    Heading home now. I'll plug in the vacuum line, check the plug wires and re-connect the ground for the ICM. I'll keep you guys posted. Thanks so much for the help so far.
  17. #17 Re: Won't start after cam install
    Okay I did all those steps. Still won't start. I am still getting that "coughing" noise out of the intake (I think). I have a fuel pressure of about 40 to 45 psi with the key in the "on" position. I also tried holding my foot on the gas, it didn't do anything.
  18. #18 Re: Won't start after cam install
    have you checked for spark yet? double checked all the grounds are bolted up? starter wires hooked up right?
    in the vid the battery sounds a little weak.
  19. #19 Re: Won't start after cam install
    Banned
    CT
    Are you sure your wires aren't backward? The #1 cylinder is in the front left, closest to the coil packs.
  20. #20 Re: Won't start after cam install
    everything is plugged in?
    maf, map, etc etc
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
