Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    This really doesn't make sense to me. Which is why I am asking about the crank keyway. I've seen it get funky on others. Unlike the HB key, the crank key would cause that exact problem because then things wouldn't be timed properly.
    One of the things I love about the 3.8 is that it's nearly the worlds simplest motor. Set balance shaft to cam, set the cam key to about 4 oclock, crank key to about 2 oclock and presto, your nearly timed right. Then the HB and sensors take care of the rest. Crank goes around twice and the cam once. So by lining up the dot you put the intake lobe in the right place. Degreeing is a good idea and it has a lot of merit. However it would be off a slight amount, not enough to bend rods like pretzels.
  2. #2 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Maybe Aaron is right. Maybe the gas hydrolocked it. I was getting a metallic sound when I tried to turn it over with the balancer on wrong. It also felt like it was binding (even with the spark plugs out). Maybe that was enough force to break/bend them. Because when my motor turns over, my pistons and valves are doing what they should be doing.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
