Thread: HID\Projector Retrofit advice and tips
Results 1 to 20 of 59
  1. #1 Re: HID\Projector Retrofit advice and tips
    GT Level Member jmoore4294's Avatar
    What I did was soldered a 9005 connector to the end of the solenoid wires and just plugged them in. Worked fine for me. This second time around, I'm keeping the stock high beam while also using the solenoid for the bixenon feature. So splice the black solenoid wire with the black wire on the car, and the red wire with the whatever the positive wire color is on the car. I would advise against using the pigtails they send to splice into the high beam wires. They are crap and the first time or two you plug/unplug them, they will come apart. Mine did anyway.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  2. #2 Re: HID\Projector Retrofit advice and tips
    May 2011
    MI
    I think I figured it out, and I'm pretty dumb if what I am thinking is true.
    Does the relay harness 9006 input plug into the stock harness 9006 output, leaving the 9005 high and sidemarker still powered in circuit? This whole time I thought it connected behind the harness and took all the power, basically bypassing all stock wirng.
    If so, this explains why I'm so confused...this is a nonexistent problem.
    I'm thinking of using posi-locks/taps for my taps.
    Also, metalcast paints apparently cure for quite some time. The red on the projectors is awesome.
  3. #3 Re: HID\Projector Retrofit advice and tips
    Quote Originally Posted by laferri2 View Post
    Yep.
  4. #4 Re: HID\Projector Retrofit advice and tips
    May 2011
    MI
    Thanks; my whole wiring diagram just fell into place. Awesome.
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. HID Projector Retrofit
    By DanGTP in forum General Tech Discussion
    Last Post: 10-04-2011, 02:15 PM
  3. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  4. Projector retrofit
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 04-17-2011, 12:46 PM
  5. Projector retrofit for 9006 04+ from 3B?
    By Ashman in forum Visual/Body Modifications
    Last Post: 01-03-2010, 12:11 AM
