Thread: HID\Projector Retrofit advice and tips
Results 1 to 20 of 59
  1. #1 Re: HID\Projector Retrofit advice and tips
    May 2011
    MI
    Man, TYC headlights are a ***** to open. They didn't use butyl tape, it's like a black adhesive liquid. I melt it with the heat gun and it immediately oozes back together around my flat head and reseals. I broke all the tabs and scratched the hell out of the lens around the seal.
    5 hours of work on ONE headlight, and I probably won't get it open until after another half hour.
  2. #2 Re: HID\Projector Retrofit advice and tips
    Banned
    Mansfield, Ohio
    Quote Originally Posted by laferri2 View Post
    First of you shouldn't be using a heat gun to seperate lenses from capsules. Sure it works but by the time you get one area melted enough to seperate and move on the area you just worked on like you've already said adheres itself back together. Put them in the oven the whole lense sealant melts uniformly, just my opinion though you can do whatever you want but it takes me about 15 minutes max to peel lenses using my method.
  3. #3 Re: HID\Projector Retrofit advice and tips
    May 2011
    MI
    Quote Originally Posted by cleangtp View Post
    I can't use my oven; I have a bird and the fumes would likely kill it. My BBQ runs way too hot and would melt it, so I'm kind of stuck.
    On the plus side, the next lens should only take maybe a third of the time; I was attempting to use the heat gun to melt a whole side at once, which wasn't working. I started melting and prying five inch sections and holding until they cooled and it went much faster. I spent two hours on the first lens allowing the glue to melt and reseal and it basically turned into a rock hard gloppy mess.
    I'm not so worried about the broken tabs as I'm going to use butyl tap and run a bead of adhesive sealant along the lens when I'm done, which should make it watertight and well sealed.
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. HID Projector Retrofit
    By DanGTP in forum General Tech Discussion
    Last Post: 10-04-2011, 02:15 PM
  3. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  4. Projector retrofit
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 04-17-2011, 12:46 PM
  5. Projector retrofit for 9006 04+ from 3B?
    By Ashman in forum Visual/Body Modifications
    Last Post: 01-03-2010, 12:11 AM
