Thread: HID\Projector Retrofit advice and tips
Results 1 to 20 of 59
  1. #1 Re: HID\Projector Retrofit advice and tips
    GT Level Member RedDawnGXP's Avatar
    Indiana
    Quote Originally Posted by laferri2 View Post
    Shrouds painted, here is a pic.
    Sanded with 400 grit, cleaned with swiffer wipe and mild soap\water. Dried. Applied two coats Dupli-color adhesive primer, two coats metalcast base coat, five coats anodized red. The slight graininess is the jewelcoat showing in the picture. For some reason my camera makes them look a little orange. They do have a little "orange peel" effect going, but that is common with the metalcasts unfortunately. Still looks good.
    Still having trouble with the wiring I'm trying to diagram. The relay harness ties up one of the stock outputs to power the ballasts. I can't figure out how to power the highs. There's no output on the harness for the highs. Do I need a second 9005 relay harness?? I'm almost certain I'm missing something simple (because I don't know much about car wiring) as no one else mentions having any issue with this.
    You just wire the solenoid wires to the highbeam wires.
  2. #2 Re: HID\Projector Retrofit advice and tips
    May 2011
    MI
    Quote Originally Posted by RedDawnGXP View Post
    Matt at TRS told me the solenoid wires are not the correct gauge to power the high-beams, and with the TRS 9006 relay harness there is no output for the solenoid, so again no power source.
    The TRS 9006 harness has only 2 (real) outputs, for the ballasts, and only one input, for one half of the stock harness aside from the ground and battery connector.
    Again, I think I'm missing something stupid and obvious.
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. HID Projector Retrofit
    By DanGTP in forum General Tech Discussion
    Last Post: 10-04-2011, 02:15 PM
  3. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  4. Projector retrofit
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 04-17-2011, 12:46 PM
  5. Projector retrofit for 9006 04+ from 3B?
    By Ashman in forum Visual/Body Modifications
    Last Post: 01-03-2010, 12:11 AM
