Thread: Crankshaft Position Sensor Replacement [*]
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 84
  1. #41 Re: Crankshaft Position Sensor Replacement [*]
    Jan 2012
    FT Campbell, KY
    Heads up, that link's broken.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  2. #42 Re: Crankshaft Position Sensor Replacement [*]
    Quote Originally Posted by ricksgpgtcolleen View Post
    page 2 its on there.
    just so you know most of the links stopped working, but there are quit a few new ones in place.
  3. #43 Re: Crankshaft Position Sensor Replacement [*]
    Search on my name and the word "easy". full write up with pics etc.
  4. #44 Re: Crankshaft Position Sensor Replacement [*]
    not good enough bill.
    we should replace these threads with yours to reduce redundancy.
  5. #45 Re: Crankshaft Position Sensor Replacement [*]
    Apr 2012
    crossville,tn
    Great write up! Had to replace my seal. Took me 20 minutes and a 15 dollar seal. When the dealer wanted to charge $175! Glad I got directed to this post. I have a Kobalt portable impact and it took the bolt right out.
  6. #46 Re: Crankshaft Position Sensor Replacement [*]
    Jun 2012
    Richburg,SC
    Quote Originally Posted by LOUDANDPROUDGTP View Post
    Fantastic write up and diagnostic details. I have been chasing this "ghost" for about three years. I must have a short in the wire or a tempermental sensor. Sometimes it does it orten and then will disappear for a while. Any one in the Houston area in for a mod day?
    couldn't figure out what ghost, my car has a ghost also, sudden very brief deceleration, any relation to yours ?
  7. #47 Re: Crankshaft Position Sensor Replacement [*]
    Aug 2012
    California
    Hello, I'm new to the forum. I was trying to get some info on replacing my crank position sensor. I found but the click here takes me to a error page, can anyone help?
    Last edited by matt5112; 08-06-2012 at 08:47 PM. Reason: don't enter links again or you'll be done here.
  8. #48 Re: Crankshaft Position Sensor Replacement [*]
    Houston
    Check billboosts post on the second page of this thread.
  9. #49 Re: Crankshaft Position Sensor Replacement [*]
    Aug 2012
    California
    I have gotten to the install and it says to torque the harmonic balancer bolt but no torque value given, anyone got that off the top of there head?
  10. #50 Re: Crankshaft Position Sensor Replacement [*]
    Houston
    111 ft/lbs
  11. #51 Re: Crankshaft Position Sensor Replacement [*]
    blap it with an impact lol
  12. #52 Re: Crankshaft Position Sensor Replacement [*]
    Aug 2012
    California
    found a web site Parts highway with a chart showing 111 lbs but is it in. lbs or ft. lbs?
  13. #53 Re: Crankshaft Position Sensor Replacement [*]
    Aug 2012
    California
    Thanks.
  14. #54 Re: Crankshaft Position Sensor Replacement [*]
    same thing, its 111 ft lbs.
  15. #55 Re: Crankshaft Position Sensor Replacement [*]
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    when in doubt blast the impact out if 111 lb is good 300 lb is better right?¿?¿
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  16. #56 Re: Crankshaft Position Sensor Replacement [*]
    Quote Originally Posted by 00grandprixgtp View Post
    Exactly.
    One quick blap of the impact is around 100-130 for mine, you'd have to have a high powered impact ot hit 300 ft lbs and be hammering on it lol.
  17. #57 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2008
    Essex, UK
    The nut that holds the balancer on; does it undo clockwise or anti-clockwise?
    Got a local garage going to replace my sensor and they asked me to find out, as they have never worked on a Pontiac before!
  18. #58 Re: Crankshaft Position Sensor Replacement [*]
    counter clockwise.. it's a bolt.
  19. #59 Re: Crankshaft Position Sensor Replacement [*]
    Feb 2013
    37.295091, -121.930053
    ok this begs me to ask this but why does it take 3 pages to answer this?
    just wondering
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  20. #60 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2008
    Essex, UK
    Thanks BillBoost37!
    Damn mechanics from 2 different garages have declined to fix my car despite the fact I have the part, and info from this forum to replace it. Got a 3rd garage looking at it next week, but will have to see how successful they are. Cost me a fortune on labour so far, and issue still not resolved!!!
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
  4. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
