Thread: Replace The Front Door Handles w/ A Sedan's Rears
Results 1 to 14 of 14
z3r0 Replace The Front Door... 05-25-2011, 07:12 PM
dpzelenak Re: Replace The Front Door... 05-25-2011, 07:15 PM
z3r0 Re: Replace The Front Door... 05-25-2011, 08:00 PM
Fivefingerdeathpunch Re: Replace The Front Door... 05-25-2011, 07:15 PM
z3r0 Re: Replace The Front Door... 05-25-2011, 08:01 PM
dpzelenak Re: Replace The Front Door... 05-25-2011, 08:02 PM
z3r0 Re: Replace The Front Door... 06-16-2011, 08:56 PM
iroc2 Re: Replace The Front Door... 06-16-2011, 10:28 PM
jteske88 Re: Replace The Front Door... 06-17-2011, 12:26 AM
z3r0 Re: Replace The Front Door... 06-17-2011, 06:10 PM
PurpleGuy Re: Replace The Front Door... 06-23-2011, 02:29 AM
z3r0 Re: Replace The Front Door... 06-23-2011, 11:36 AM
z3r0 Re: Replace The Front Door... 07-15-2014, 06:50 AM
outonthetiles Re: Replace The Front Door... 11-16-2014, 12:49 PM
  1. #1 Replace The Front Door Handles w/ A Sedan's Rears
    Bunnell, FL
    Parts Needed
    1 pass side rear door handle off a sedan
    1 drivers side rear door handle off a sedan
    2 boxes "Door lock rod clips" from advanced p#75450
    (what you really need is the black clips in the boxes)
    2 small stainless steel bolts 2" long roughly the same as a standard rivet
    2 stainless steel nuts
    ALOT OF PATIENTS
    Tools
    T30 Torque Star (Long Handle)
    10mm Ratchet w/ Long Extension
    Flat Head Screw Driver
    Razor Blade
    Time
    15 Mins Per Side
    Process
    1. Gather the parts list & tools
    2. this is the clip you must replace (the black one)
    3. we need to remove the door panel, start by removing the dressing clips w/ a flat head (mine is curved at the tip so it's more like a mini crowbar)
    4. now undo the torque screws, there is only 2 and they are a T30
    5. now pull the whole panel off and disconnect the wires, the door panel is now able to be removed
    6. remove the plastic protector screen
    7. remove the Styrofoam
    8. now remove the two 10mm bolts holding in the door handle
    9. now carefully remove the door handle from the car until the rods prevent it from coming out any farther
    10. now follow the handle rod down till you find the locking clip, it's black and a though bugger, but a little brute force and it'll pop open
    11. now take a razor blade and break off the locking tabs (do this now for the rear handles as well
    12. remove the handle completely, here you can see the brackets are on the wrong side.
    13. cut the rivets off the old handle where the bracket is and the new handle on the same side
    14. remove the bracket off the old handle
    15. insert it into the new handle, you will need to bend the locking peg so it can fit into the channel, now here comes the hard part, bend the bracket so that the one with the prong goes from 90 degrees to 45 degrees. this step is the key to the whole thing working correctly. if it isn't bent correctly to lock the bracket into place this mod will not work!!!
    16. i left the old bracket on the door handle. it doesn't really matter if you leave it or not
    17. i used a stainless screw and nut instead of a rivet to replace the one we had to cut out
    18. another important step is to place the black rod clip into the new bracket before you put the rod in
    19. this is how you place the rod back in. now carefully place the handle back into the hole. loosely add the bolts.
    20. straighten the rod, and clip the rod back into it's holder.
    21. tighten the bolts up completely
    22. check your work (also check the windows in case your rod is in the way)
    23. reinstall the styrofoam
    24. replace the plastic
    25. reinstall the door panel
    26. congrats you have just done this mod +35 exp
    before
    after
    Please Post Your Results In This Thread
    Update Log:
    Replaced the pictures to work (07/15/14)
    Added PDF download of build in case Facebook kills the pics, again... (07/15/14)
    I do apologize for the potato pics (07/15/14)
    Download PDF
    I'm a Sex Offender
  2. #2 Re: Replace The Front Door Handles w/ A Sedan's Rears
    nice idea looks good, just dont realy get it theo, is it just to clean it up?
    SMGPFC Member #10
  3. #3 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Bunnell, FL
    it's a poor mans way of shaving the doors a bit
    I'm a Sex Offender
  4. #4 Re: Replace The Front Door Handles w/ A Sedan's Rears
    sweet deal man.
    Just gotta hope your remote dont die
  5. #5 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Bunnell, FL
    sweet deal man.
    slim jim in the trunk
    I'm a Sex Offender
  6. #6 Re: Replace The Front Door Handles w/ A Sedan's Rears
    either way it does look very nice and clean
    SMGPFC Member #10
  7. #7 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Bunnell, FL
    LowlyfeGTP had these on his silver gtp
    http://www.cardomain.com/ride/256686...iac-grand-prix
    just sayin
    I'm a Sex Offender
  8. #8 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    nice idea cleaned it all up a little bit
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  9. #9 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Yoga city
    You know I was gonna do this but was worried about fob going dead. Didn't want to have to smash a window
  10. #10 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Bunnell, FL
    i keep a slim jim and a spare battery in the trunk
    I'm a Sex Offender
  11. #11 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Never Never Land
    Bam...problem solved about the key fob lol....but seriously...that is slick! I like it...might have to do it lol
  12. #12 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Bunnell, FL
    well i now have to readjust both door handle rods. oh well price you pay for sexiness
    I'm a Sex Offender
  13. #13 Re: Replace The Front Door Handles w/ A Sedan's Rears
    Bunnell, FL
    was sent a message on face book
    added most of the pics back
    added a download of the guide at the bottom when the pics die again
    i do apologize about the potato quality it was '11 and a flip phone iirc
    I'm a Sex Offender
  14. #14 Re: Replace The Front Door Handles w/ A Sedan's Rears
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    If you use rear door handles from an Impala instead, there is no need to modify anything on the door handle. The bracket is already on the correct side.
  1. new door handles
    By z3r0 in forum Visual/Body Modifications
    Last Post: 07-06-2011, 04:50 PM
  2. Keyless door handles
    By jteske88 in forum Visual/Body Modifications
    Last Post: 03-09-2011, 10:29 PM
  3. sticking door handles
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-01-2010, 01:22 PM
  4. chrome door handles
    By smittrailfire in forum Visual/Body Modifications
    Last Post: 10-05-2008, 11:27 AM
