Thread: Question about replacing supercharged drive belt.
Results 1 to 17 of 17
  1. #1 Question about replacing supercharged drive belt.
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Okay, I've read some instructions, but Afghanistan wasn't kind to my brain and I confuse easily. Now, for the grooved idler pulley, it is a simple "Lefty loosey, righty tighty" deal, is it not? My original plastic one, whose the brain dead engineer that thought plastic was a good idea to make a pulley out of?? fell apart in my hand when I was testing if it was good. I have a new metal one now. Now, once I replace the grooved idler pulley, is all I have to do is loosen the tensioner pulley by using the "righty loosey, lefty tighty" rule? Now, is this done to to replace the pulley, or does this release the tensioner?? (this is the part confusing me) If this is just how you release the tension, do I just loosen the bolt in the centre of the tensioner pulley, then slip the new belt on, and then tighten the tensioner pulley bolt? Any and all help will be greatly appreciated. The local GM guys want like $170.00 for labour (belt is .8 hours, pulley is .5 hours.) And I figure even I could do this. After all, I was able to replace the oil cap with a nice billet aluminum one.
  2. #2 Re: Question about replacing supercharged drive belt.
    it should be a normal bolt on the idler. the tensioner, i used a 15 mm socket on a my ratchet with a small pipe for extra leverage. turn the bolt so the tensioner pulley moves away from the belt, then slide the belt off the pulley then the s/c pulley, its a snug fitting belt, not a whole lot of play even with the tensioner fully turned.
  3. #3 Re: Question about replacing supercharged drive belt.
    GT Level Member Shiftingshaddow's Avatar
    KC
    .8 hrs for a belt? how about 2 minutes?
    .5 for a pulley? how about 1 minute?
    unbelievable.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  4. #4 Re: Question about replacing supercharged drive belt.
    its a ten minute job really, (tops) i just changed a idler last month.
    i bet the dealer ship takes longer to check the car in, then do the paper work, and then check it out and pay, vs actual time working on the car.
  5. #5 Re: Question about replacing supercharged drive belt.
    KC
    i know how it works. i worked at shop for awhile. .8 hrs for a belt when it literally takes a few minutes on a gm. it still makes me mad. they should just have a flat rate on some things. there is the 200% markup on the part to begin with. telling a customer .8 hr on a belt and .5 on a pulley is theft plain and simple. just say the dollar amount. gotta make a buck but that is pure deception.
  6. #6 Re: Question about replacing supercharged drive belt.
    Mar 2013
    Manitoba, Canada
    One more question, how easily spun are the smooth idler pulley and the tensioner pulley supposed to be? I checked them out by hand, and they didn't wiggle, but you couldn't spin them and have them spin for 5 seconds or so, they basically just turn.
  7. #7 Re: Question about replacing supercharged drive belt.
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Yeah they should turn freely with absolutely No noticeable wiggle or grinding noise. There will always be some noise while its spinning, but trust me youll know if its on its last leg. If you hold it firm in your hand and rock back and forth it should feel like it's working smoothly then you're good to go. Don't mess with it too much so you don't cause the bearing to fail prematurely.
  8. #8 Re: Question about replacing supercharged drive belt.
    Nov 2011
    NY
    The results of when the pulley doesn't turn freely...
    Its really a simple job with little effort... Pulley is like $12 so forget the stealership and jump right in!
  9. #9 Re: Question about replacing supercharged drive belt.
    Mar 2013
    Manitoba, Canada
    Up here in Canada We don't get $12 pulley and $20 Belt prices, buy I got my belt and Pulley for about $60. Think I spent 15 minutes changing the pulley AND installing the belt. On a side note, what I thought all along was cool Supercharger whine, was in reality a grooved idler pulley on it's way to seizing up.
  10. #10 Re: Question about replacing supercharged drive belt.
    Feb 2013
    37.295091, -121.930053
    i had that on a truck the tensioner pulley broke the f off cheap a$$ plastic. new belt and pulley under 40 if I rember right.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: Question about replacing supercharged drive belt.
    Mar 2013
    Manitoba, Canada
    if anyone can guess what specullaaas means i would be shocked!!.
  12. #12 Re: Question about replacing supercharged drive belt.
    I live here. TLSheff's Avatar
    Quote Originally Posted by coolone View Post
    At least you still had some plastic left. All I had was a bearing that wouldn't turn and a missing belt.
  13. #13 Re: Question about replacing supercharged drive belt.
    Feb 2013
    OMG you looked it up lol thank you google lol. When i looked it up it kept sending me to gingerbread men.
  14. #14 Re: Question about replacing supercharged drive belt.
    Mar 2013
    Manitoba, Canada
    One thing I would like to say to all who helped me out on this pulley and belt project is a great big thank you! Since returning from Afghanistan, I suffer from PTSD. One of the symptoms, is I have lost a great amount of confidence in my ability to do things. If the labour wouldn't of been so high, I probably would of had the dealer do this job. However, the people of this forum explained everything to me so very clearly, that when I opened the hood and looked at the project, I decided to give it a try. It was exactly as you all said. How to replace the pulley, how to use the tensioner, and how to put the belt back on. I am now starting to think that there might be more projects like this that I might be able to do on my grand Prix. Once again, thank you all very much!!
  15. #15 Re: Question about replacing supercharged drive belt.
    i must say, we've motivated girls to do work on their cars. its kinda what we do lol i cant see spending good money at a shop for things a simple ratchet set and your time can fix.
    you still got skills, just get in there and take over. hope you feel better, and thanks for kicking some ass over seas too. (and making it back home)
  16. #16 Re: Question about replacing supercharged drive belt.
    Apr 2013
    MI
    I just had to replace this pulley yesterday and all I found were chunks of plastic and the bearing. I was lucky the belt didnt come off completely. It was rubbing and I smelled the burning belt. A trip to autozone, $36, and 10 mins later belt and pulley were replaced. Going to look at replacing some of the other pulleys soon to avoid this again.
  17. #17 Re: Question about replacing supercharged drive belt.
    If you can budget the extra money, several pulleys have metal heavy duty replacements but you have to ask for them usually. They also usually cost double, but work much much better and longer.
  1. Has anyone in the US Adapted A gilmer belt drive to the l67
    By vsl67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2012, 11:57 AM
  2. COG drive belt?
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 07-01-2012, 01:05 PM
  3. Drive without supercharger belt?
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2011, 01:04 PM
  4. Drive Belt Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 05-24-2009, 05:44 PM
  5. Drive Belt Tensioner Replacement [*]
    Last Post: 01-03-2008, 10:54 PM
