Thread: Redneck rusty resonator fix
Results 1 to 15 of 15
  1. #1 Redneck rusty resonator fix
    hangover park IL
    it started last year with a quiet putting....then it slowly gets louder till your ears drone even after you get out of yer heap...probably shoulda fixed it a couple months back.....ah well i went and fixed it.
    dont buy a new resonator...the oem pos that makes the buick v6 think its breathing through a crazy straw...but has the quietest "3800 blatt" youll find outside of a 3800 idling at 0 rpm.....
    but enough of my rationalizing of my cheapness...
    the resonators always rust out at the body seam, usually hidden by the steel heat shield if you cant see it.
    if the rest of the oem exhaust is in ok shape, time to say "****it"
    parts needed, alum foil, hose clamps, prybar, hammer, mullet
    at this point you can both curse and thank the gods of iron oxide. your heat shield is probably already rusted away at several of the spot welds that held it to the resonator.
    a bit of gentle persuasion with a prybar is usually all you need to separate the razor thin rusty metal...that seems to scream "imma cut yew" and make you wonder if your up to date on yer tetanus shots.
    once the shield is off, you can fingerbang the resonator and determine how far along the seam its rotted...take note for how much reynolds to steal from the kitchen....i wrote the measurement with my finger in the dirt on the underbody....and on the countertop from the looks of the fingerprints everywhere.
    now take the heat shield...if you have a vice, take a swig, and use your vise to flatten the spot weld indents around the edges...then get a ball peen hammer, and carefully beat the **** out of the other spot weld bosses to flatten em out. ****tion is greater than form in this area...take out some rage...
    carefull bending will either cut you up...or close the dia of the shield so its closer to that of the resonator and fits goodentight...like a german virgin.
    go back to the vice on the bench, swig, set it on vise, dont do that dummy, move crap on bench and put it where you wont be picking up glass shards due to dumbassery.
    grab aluminum foil...crinkle it repeatedly so its "fluffy", crapload of layers (2 layers folded into 1/2 and other 3rds lengthwise)... roll the edges to act as the new sealing gasket.
    put wide foil in shield, put smaller inside, slightly compress, slip over muffler keeping care to clock the middle spot weld holes to one side of the seam (dont dead center it...holes over holes...no bueno brochacho.)
    now dig around till you find the loop of hose clamps and air intake clamps you've been collecting from the junkyard for the last 20 years...along with spare nuts/bolts/fuse/relays
    WAT? you dont collect em? well **** dude, so much for a free fix...go buy some dummy...string em together if need be...maybe use some mechanics wire or some sweet vintage coathangers.
    hose clamp that ****...or twist the coathanger, pick yer poison.
    enjoy quiet car once more
    ~James~ Psychotic Gearhead
  2. #2 Re: Redneck rusty resonator fix
    thats as red neck as it gets. lol
  3. #3 Re: Redneck rusty resonator fix
    hangover park IL
    at least its not a cambells or folgers fix? lol
  4. #4 Re: Redneck rusty resonator fix
    not even gonna lie. ive used coffee cans and hose clamps in the past lol its never a perfect fix, but it sure will make it sound better.
  5. #5 Re: Redneck rusty resonator fix
    hangover park IL
    im a huge fan of recycling
  6. #6 Re: Redneck rusty resonator fix
    hangover park IL
    no seriously, i recycled the huge attic fan into a free standing, cut the **** out of you/brapp yer knuckles fan outside the back garage door for my summertime "gayrajnado"
    at least i killed the bee's nest that were in the transmission pile....the fan would blow em right into the garage
  7. #7 Re: Redneck rusty resonator fix
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    This is awesome, much more redneck than the 2x4 rusty strut tower fix.
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Redneck rusty resonator fix
    HUDSON
    Better get a carbon monoxide warning detector in your car.
  9. #9 Re: Redneck rusty resonator fix
    hangover park IL
    well maybe before i fixed it....dont need one after i fixed it
  10. #10 Re: Redneck rusty resonator fix
    Banned
    Aug 2011
    Pittsburgh, PA
    Lol nice
  11. #11 Re: Redneck rusty resonator fix
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Always gotta get a dig in, huh. That car's strut towers were a piece of **** but it was still faster than yours
    OP, nice fix though, haha.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  12. #12 Re: Redneck rusty resonator fix
    hangover park IL
    ive been doing the wooden strut tower fix since 03/04
    as long as you oil down the area real well you'll retard the rust enough to get quite a few more years out of the car...its just sucks cause you should be sorta pre emptive with the wood once the rust bulge travels the whole outer wheel housing junction
  13. #13 Re: Redneck rusty resonator fix
    GT Level Member Hardonyomom's Avatar
    aurora
    That looks like more trouble than i would want to get into but good job on that project.
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  14. #14 Re: Redneck rusty resonator fix
    hangover park IL
    more trouble?
    its popping the 4 remaining spot welds off (that havent rusted away completely...yet) to get the shield off, a hammer, some alum foil and some hose clamps.
    took 10 minutes 15 if your counting the drinking
  15. #15 Re: Redneck rusty resonator fix
    if mine had only come with a heat shield lol
    new glass pack installed, priceless.
  1. Redneck rusty rear strut tower fix
    By hensleya1 in forum How To Write-Ups/Tech Tips
    Last Post: 02-21-2015, 03:43 AM
  2. Crazy Redneck Mudding! Bottomless Hole!
    By rynoman03 in forum Off Topic Discussion
    Last Post: 09-07-2012, 05:37 PM
  3. S. GA, but not a redneck. :)
    By LALAW in forum Introductions/Noob Questions
    Last Post: 03-16-2009, 09:48 PM
  4. you might be a redneck if...
    By Curtis in forum Off Topic Discussion
    Last Post: 01-13-2009, 09:14 PM
  5. redneck santa
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-29-2008, 05:16 PM
