Thread: Crankshaft Position Sensor Replacement [*]
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 84
  1. #1 Re: Crankshaft Position Sensor Replacement [*]
    Spring Hill, Tn
    So my husband and I had to replace this sensor this weekend and I am soo thankful that I had found this thread..... finding the bolts to go into the harmonic balancer was a chore...we got the 4inch ones and they were actually too long.....so we would say maybe a 3 1/2 inch ones if you can find them...but I am soo glad that I had found this or our car would still be sitting in the garage thank you very much!!!!!!
  2. #2 Re: Crankshaft Position Sensor Replacement [*]
    Houston, TX for now
    Fantastic write up and diagnostic details. I have been chasing this "ghost" for about three years. I must have a short in the wire or a tempermental sensor. Sometimes it does it orten and then will disappear for a while. Any one in the Houston area in for a mod day?
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  3. #3 Re: Crankshaft Position Sensor Replacement [*]
    Jun 2012
    Richburg,SC
    Quote Originally Posted by LOUDANDPROUDGTP View Post
    couldn't figure out what ghost, my car has a ghost also, sudden very brief deceleration, any relation to yours ?
  4. #4 Re: Crankshaft Position Sensor Replacement [*]
    Aug 2012
    California
    Hello, I'm new to the forum. I was trying to get some info on replacing my crank position sensor. I found but the click here takes me to a error page, can anyone help?
    Last edited by matt5112; 08-06-2012 at 08:47 PM. Reason: don't enter links again or you'll be done here.
  5. #5 Re: Crankshaft Position Sensor Replacement [*]
    May 2008
    Florida
    Just did this today. Handy having the page saved as a favorite on my Droid for a reference!
  6. #6 Re: Crankshaft Position Sensor Replacement [*]
    Oklahoma
    No problem, glad I could help out. Print a copy of that thing out if you got a printer that will do the pictures well enough and save it, share it, spread it around or point people here that need it if you come across anyone.
  7. #7 Re: Crankshaft Position Sensor Replacement [*]
    Donating Users
    Columbus OH
    Scotty, Thank you SO much for the write up - My brother-in-law (who is an awesome mechanic and all-around awesome guy) replaced my CPS for me and now my 01 GTP is running like a top again. Of course we had to replace 2 window regulators (total of all four replaced now) and the Multi-function switch in the steering column too. I hope I'm done with repairs for a while. I really can't complain too much this is the first real money I've had to put into it. Much better than a new car payment. Thanks!
  8. #8 Re: Crankshaft Position Sensor Replacement [*]
    Oklahoma
    You're more than welcome.
  9. #9 Re: Crankshaft Position Sensor Replacement [*]
    Aug 2008
    as
    SyntheticShield, I had a question.
    I'm a little confused on the step where you said to, "Clamp a pair of good heavy duty vice grips on the flywheel towards the front side of the engine."
    I was going to attempt this later today and want to know exactly how and why to do this? thanks in advance.
  10. #10 Re: Crankshaft Position Sensor Replacement [*]
    Feb 2008
    West Jordan, UT
    Quote Originally Posted by Panto911 View Post
    You do this to prevent the crank from spinning when you're trying to remove the harmonic balancer bolt.
    If you look at this picture you can see exactly where to put it under the car.
  11. #11 Re: Crankshaft Position Sensor Replacement [*]
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    about one year ago my dad was having issues with is '00 GP, I gave him this site and write-up. he used that page and successfully changed the CPS. then I mailed synthetic the bad CPS Car still runs flawlessly
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  12. #12 Re: Crankshaft Position Sensor Replacement [*]
    Just did this today - I had to run out to the hardware store and knew exactly what I needed. Thanks for the writeup!
  13. #13 Re: Crankshaft Position Sensor Replacement [*]
    Louisville, KY
    Worked great for me, still had to use 3 sets of pullers to piece mill the exact parts that I needed for this but I didn't have a problem at all working on the wife's 2000 GT.
    My Cardomain
  14. #14 Re: Crankshaft Position Sensor Replacement [*]
    Nashville TN
    This procedure made my day. I never thought I would get that bolt to break free, especially after snapping a 1/2 in. drive extention. After reading this write up it all became perfectly clear. Thanks for taking the time to explain step by step.
  15. #15 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2008
    philly
    Well just did this got a Duralast sensor from AZ. could not get my bolt loose with a 36" breaker bar it had a pound of red thread locker on it; so i did the "disable the ICM, wedge the breaker bar on the support and give it crank", it broke free instantly. I used a lisle 3300-3800 puller it came with the bolts that fit perfect as well as the metal rod to protect the crank threads. big thanks for this how-to and TorqueAutoMotiv for helping me out.
  16. #16 Re: Crankshaft Position Sensor Replacement [*]
    Jun 2010
    Stanwood, MI
    Thanks for the how-to. Made this so much easier.
  17. #17 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2011
    montana
    Iam new to the forum but this thread talks about replacing a cps,but there is nothing here is the link just no longer active .i need to find and change the cps but i cannot find it ,the is a 2002 grandpriz 3.1liter
  18. #18 Re: Crankshaft Position Sensor Replacement [*]
    Jack and support passenger side front of car.
    Remove tire
    Remove plastic splash shield in front of harmonic balancer
    Untension belts
    Remove crank bolt (24mm)
    Using a balancer puller and m6 x 1.00 pitch bolts about 60-75mm in length pull the balancer
    Disconnect crank sensor electrical
    Remove plastic crank sensor shield
    Remove crank sensor (2 x 13mm bolts and wiggle it)
    Reverse for installation.
    Tip, when reinstalling the plastic crank sensor shield. Ensure each of the three nubs have clicked on the bolt ends.
  19. #19 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2011
    montana
    Thank you. If this dont work do you have pics and how to replace a camshaft position sensor and where it is located on a 2002 3.1 L grandprix
  20. #20 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2011
    montana
    where is the camshaft position sensor. the car stall for no reason . i check for spark and there is no spark .i changed the icm and the crankshaft position sensor.any help would be greatly appricated
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
  4. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
