Thread: Crankshaft Position Sensor Replacement [*]
Page 5 of 5 FirstFirst ... 345
Results 81 to 84 of 84
  1. #1 Re: Crankshaft Position Sensor Replacement [*]
    Mar 2013
    St. Louis
    Got it changed. What a pita. Couldn't find my channel locks so I used some vise grips. 1/16 of a turn at a time. Its so nice to be able to park and not have a single drop of oil on the ground. Its been bad but over the last couple days it got to leaking a quart a day. Definitely worth the $20 part. Thanks for all your help guys, I'm back to liking my car again
    Sent from my SPH-L710 using Tapatalk 2
  2. #2 Re: Crankshaft Position Sensor Replacement [*]
    Nov 2014
    Indianapolis
    This HOW TO write-up on Replacement of a Crankshaft Position Sensor has been added to the How To section and can be found HERE
    When I click on the "HERE" link nothing shows up. Did this get deleted? Thanks in advance!
    Jeremiah
  3. #3 Re: Crankshaft Position Sensor Replacement [*]
  4. #4 Re: Crankshaft Position Sensor Replacement [*]
    Nov 2014
    Indianapolis
    Thank you! Got it
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
  4. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
