Thread: Simple Intake (pictures)
Page 8 of 21 FirstFirst ... 67891018 ... LastLast
Results 141 to 160 of 419
  1. #141 Re: Simple Intake (pictures)
    drill a hole in the silicone piece.
    no grommet needed.
  2. #142 Re: Simple Intake (pictures)
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    Nawarkk, Does your filter need to be oiled?
    Also, what size coupler do I need? 4" on both sides?
    Thanks, J.
  3. #143 Re: Simple Intake (pictures)
    Bunnell, FL
    i'm a chef, so i worked my good hunting knife in order to fit the iat inside the center of the cone
    so for my project i leave the coupler with the plug connectors
    I'm a Sex Offender
  4. #144 Re: Simple Intake (pictures)
    West Side Michigan
    Quote Originally Posted by Xanthous View Post
    Thanks, J.
    The filter I used, is on you have to oil. You can use any filter you like.
    the coupler I used was I believe 3 1/2, but since it was rubber it stretched over the throttle body, and pvc pipe. Made it so it had a tight fit then.
  5. #145 Re: Simple Intake (pictures)
    May 2011
    Waterford Michigan
    I have a 97 gtp if I built this CAI system would I have to move my coolant overflow?
  6. #146 Re: Simple Intake (pictures)
    Quote Originally Posted by Jbruce View Post
    Nope, just make it short enough to not hit the overflow tank.
  7. #147 Re: Simple Intake (pictures)
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    I Have a '97 and I have a 9 in cone and it JUST fits with the 45* bend.
    -ljmonnin12
  8. #148 Re: Simple Intake (pictures)
    May 2011
    Waterford Michigan
    Alright thanks guys.
  9. #149 Re: Simple Intake (pictures)
    Nov 2010
    Sidney, OH
    Yuppers.
    -ljmonnin12
  10. #150 Re: Simple Intake (pictures)
    Bunnell, FL
    mine pictured above is a 97 gtp
    I'm a Sex Offender
  11. #151 Re: Simple Intake (pictures)
    May 2011
    Waterford Michigan
    Do you guys have any good ideas on a downpipe?
  12. #152 Re: Simple Intake (pictures)
    Grand Rapids, MI
  13. #153 Re: Simple Intake (pictures)
    Apr 2011
    St. Louis
    Nawarkk, what paint did you use for the pvc pipe?
    Going to the store today. So a 3.5" coupler fits over a 3" pvc pipe? I think the coupler used by the op is called a 3" coupler but in reality is 3.5".
    I installed today, everything went good. I used;
    Spectre 9732 Filter
    3" rubber coupler (actually 3.5")
    4" band clamp+3" band clamp
    3" 45 degree pvc pipe elbow.
    Then cut the bottom piece off the stock air intake to set the pcm on so it wouldn't flop around. Filter fit good but was tight (hits cross beam and pcm)
    Hope to have pics up soon. Thanks for the help.
    Justin
  14. #154 Re: Simple Intake (pictures)
    pennsylvania
    what do you do with the plugs and wires that plug into the intake?
  15. #155 Re: Simple Intake (pictures)
    Jul 2008
    Tampa, FL
    Quote Originally Posted by jspangler22 View Post
    make holes for em and set them in there...or get a grommet that fits it, and install it in your piping...
  16. #156 Re: Simple Intake (pictures)
    Donating User Odi's Avatar
    Chicago South Suburbs
    putting a 3in to 4in coupler on the TB SUCKED DICK ASS VAGINA PENIS. i suggest getting a 3.5in to fit over the TB.
  17. #157 Re: Simple Intake (pictures)
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Just get a 4" coupler and tighten it down on the TB.... probably easier to find than a 3.5 - 4" coupler and it will accomplish the same thing
    2000 Grand Prix GT- DIY Spectre HAI, KYB GR-2 Struts, GMPP Front and Rear Sway Bars, GMPP Front and Rear Strut Tower Braces w/ Don Rome Brackets
    Soon to be Installed: Poly Bushings + Poly End Links- Front and Rear GMPP Sway Bars
  18. #158 Re: Simple Intake (pictures)
    Antioch, IL
    I found a 4" on the tbody is way to huge
    2009 Challenger SRT8
    Expert at being gay.
  19. #159 Re: Simple Intake (pictures)
    3.5" Couper on the TB is the way to go guys.
    Or a 4" if you have a larger TB...such as the Billet ZZP, N*, or LS1
  20. #160 Re: Simple Intake (pictures)
    Apr 2011
    St. Louis
    Here's my intake. (very similiar to nawarkk's) finally got some pics.
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
