Thread: Simple Intake (pictures)
Page 21 of 21 FirstFirst ... 11192021
Results 401 to 419 of 419
  1. #1 Re: Simple Intake (pictures)
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Quote Originally Posted by Rod2003GT View Post
    My simple set up under $50. Installed this morning.
    Have you noticed any ticking sounds after installation? I have a similar setup and think that the intake is causing/amplifying the sound.
  2. #2 Re: Simple Intake (pictures)
    SE Level Member Rod2003GT's Avatar
    Sep 2015
    CT
    Quote Originally Posted by bonerjamz03 View Post
    When the car is cold it makes a hell of a noise but smoothed out once you get moving or warmed up. Their is an AC port under my 45 elbow that would make a rattle/vibration after install. I put a small piece of rubber between the two and the noise is gone.
    Sent from my S208 using Tapatalk
    2003 Pontiac Grand Prix GT
  3. #3 Re: Simple Intake (pictures)
    Apr 2011
    North Los Angeles
    Whats your break down on price and parts? Have you noticed a difference in performance or sound? If s how much? Looks nice.
  4. #4 Re: Simple Intake (pictures)
    Sep 2015
    CT
    Quote Originally Posted by steelholder View Post
    The 4" to 3" coupler on the TB was from Lowe's. About $6. Filter, elbow, small connector with hole for IAT sensor all from Advance Auto. With $5 Speed Perk and an additional discount code all came to $43
    More noise at cold start and wot. Installed a ZZP downpipe last night as well. Runs great. Plenty of pep for an
    N/A.
  5. #5 Re: Simple Intake (pictures)
    Apr 2011
    North Los Angeles
    N/A.
    is the down pipe alone going to make a big difference without a complete exhaust system? Besides the cai what else have you changed or added?
  6. #6 Re: Simple Intake (pictures)
    Sep 2015
    CT
    That's about it besides routine stuff like plugs, wires, fuel filter, Mobile1, PVC, coolant flush. I only changed the cat back due to holes in the resonator and mufflers. Keep the stock cat back if yours is good.
  7. #7 Re: Simple Intake (pictures)
    SWPA
    The cat back isn't making you lose power. The downpipe might make a 1 hp difference. The intake probably makes no difference in power.
    BTW, here is my homemade intake.
  8. #8 Re: Simple Intake (pictures)
    QC, Canada
    Sorry to breathe new life into an old thread... lol
    Care to share your parts list, if you don't mind? Also, you have that (PCV??) hose connected in the back, right?
    2007 Pontiac Grand Prix GT Supercharged | 105,000 kilos / 65,200 miles
    DEAD (9/28/'13) 2000 Pontiac Grand Prix GT | 161,400 kilos / 100,300 miles
  9. #9 Re: Simple Intake (pictures)
    Quote Originally Posted by KingVee View Post
    Check the 1st page.
    Or scroll through it.
    There are plenty of different setups with different parts to use.
  10. #10 Re: Simple Intake (pictures)
    QC, Canada
    Quote Originally Posted by blueguy View Post
    Check the 1st page.
    Oh, I know blue, just that his setup is my favorite for 04+, I like the fact that it goes further out.
  11. #11 Re: Simple Intake (pictures)
    SWPA
    Yes the PCV is hooked up in the back on the intake. I extended the factory hose, then I drilled a hole and used a grommet and popped it into the intake where it fits just like stock.
    I'll have to go back and see what I can find on my parts list since its been so long.
  12. #12 Re: Simple Intake (pictures)
    SE Level Member Pairsnpaint's Avatar
    Ocala, FL
    Let's bring back an old thread from the dead....
    I'm getting back into GTP's after about 10 years with a '98 Daytona Edition. One of the first things I plan to do once it gets delivered is to do a cone air filter like I had on my '02 (my original setup is shown on page 6 of this thread). My question is: Is there a clearance issue with the '98? I heard that the overflow bottle is in the way but I don't have the car here yet to verify. I plan on using a 9" cone with a 4" diameter pipe, maybe updating to a real carbon fiber piece instead of the aluminum. Any suggestions or first-hand knowledge is appreciated!
    Hal
    Ocala, FL
    2002 GTP Coupe - 2016 Chevy Equinox
  13. #13 Re: Simple Intake (pictures)
    Apr 2011
    North Los Angeles
    I wish it was. I'm getting the p0420 and the system running lean code. I'm in ca and am forced to pay around 5~600 for a legal one. Might have to go another route..
  14. #14 Re: Simple Intake (pictures)
    SWPA
    p0420 is not caused by holes in the catback.
  15. #15 Re: Simple Intake (pictures)
    Apr 2011
    North Los Angeles
    I didn't read close enough I meant catalytic
  16. #16 Re: Simple Intake (pictures)
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    I like this one more. In the fender. This write up includes a parts list. Its for 97-03 but I'm sure most of it translates over.
    http://www.grandprixforums.net/threa...derwell-intake
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
