Thread: Simple Intake (pictures)
Page 19 of 23 FirstFirst ... 91718192021 ... LastLast
Results 361 to 380 of 454
  1. #361 Re: Simple Intake (pictures)
    Quote Originally Posted by Swole View Post
    Does yours also have the crazy loud sucking sound? I mean I knew the sound would change but the sucking sound on this thing is crazy lol
    Yes, it's normal.
    It's the air passing through the IAC passage inside the throttle body, the stock intake muffles that sound.
  2. #362 Re: Simple Intake (pictures)
    Dec 2012
    Where 4T65E's were born
    Should go away after it warms up and the iac valve closes. Mine's loud on cold startups too but after 10 mins of idle, or after putting it in gear it stops.
    Sold.
  3. #363 Re: Simple Intake (pictures)
    Dec 2012
    St. Paul
    Here's my simple intake. Yeah I know, it sucks in hot air from the motor. But for now, I don't care. lol It sounds better than the stock intake and makes the engine bay a little more presentable. I got a 3" rubber coupling, 3"-45 degree pvc "street pipe" and a 4" cone K&N filter. The street pipe, on one end, is "flared" to a 3" ID and almost 4" OD so the 4" K&N fit perfectly on there. The other end of the pipe is a 3" OD. Painted the PVC w/ gloss black. Popped a 1/2" hole in the pipe for the sensor. Used a rubber grommet as well as some silicone adhesive for a good seal around the sensor. Can't get much easier than that! When it gets warmer I'll be doing a fender well intake but this will do for now. I used the old zip tie method for the PCM but I will be going to the yard this weekend to get a Blazer tray to mount the PCM to.
    part list of this guy and where to get it?
    2007 GXP
  4. #364 Re: Simple Intake (pictures)
    Florida
    Elbow is from Home Depot or Lowes. Use any air filter you want. The rubber connectors are also from lowes/hd
    just air filter, plastic elbow, connectors, and paint
  5. #365 Re: Simple Intake (pictures)
    Aug 2013
    McDonald PA
    Quote Originally Posted by Schmidty View Post
    You can also drill holes in the coupler for any vac lines you have. My 06 had one and I just drilled it slightly smaller and it fits like a glove
  6. #366 Re: Simple Intake (pictures)
    Mar 2012
    Cincinnati
    3" rubber coupling (had a metal sheet around it that the 2 clamps were mounted to. i pulled the metal sheet off and used the clamps), 3"- 45 degree "street pipe" elbow (I say street pipe bc that's what the label at Menards said). it is 3" outer diameter on one end and 3" inner on the other side, 4" K&N filter (you can choose whatever filter you want). the 4" filter mounts perfectly over the 3" inner diameter end. Drilled a 1/2" hole for the sensor and then used a 1/2" rubber grommet and silicone adhesive to seal the hole around the sensor. then just used high temp gloss black paint to paint it. Sorry this may be a bit confusing. If you need me to, I'll be glad to roll down to menards and take pics of the exact parts I used to make it easy on you man.
    1999 Grand Prix GTP
    GXP front brakes, Comp G wheels, Dual HUD pod, Aeroforce Interceptor & boost gauge, GMPP front & rear strut brace, catless downpipe & resonator delete, homemade short ram intake w/ K&N filter
  7. #367 Re: Simple Intake (pictures)
    Dec 2012
    St. Paul
    So some of these guys..
    http://www.menards.com/main/building...210-c-5776.htm
    then get this guy...
    http://www.menards.com/main/plumbing...654-c-8547.htm
    and drill a 1/2" hole for the sensor and then were did you get the grommet?
    2007 GXP
  8. #368 Re: Simple Intake (pictures)
    Mar 2012
    Cincinnati
    Yes on the second link. The first link are just clamps. Here is sorta what the rubber coupling I bought looks like. It has this metal sheet around it that the clamps are connected to. Just break the clamps off of the metal sheet and just use the rubber and clamps. http://www.menards.com/main/plumbing...878-c-9371.htm
    I got the rubber grommet at Ace. It was in their nuts and bolts section in one of the drawers. They had very few but you need one with a 1/2" inner diameter for the sensor to fit snug into. Then I got some silicone adhesive to make sure the seal was tight.
    1999 Grand Prix GTP
  9. #369 Re: Simple Intake (pictures)
    Aug 2013
    McDonald PA
    You have a maf the whole is for the iat sensor that the 97-03 have just incorporate the maf. And if you have a vac line. Like I did being an 06 drill a hole into the rubber coupler slightly smaller and jam it in there
  10. #370 Re: Simple Intake (pictures)
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    Just did this on my car. Thanks for the write up! K&N 9" FTW!!! Loud as Betty when she screams my name
  11. #371 Re: Simple Intake (pictures)
    SE Level Member Luckys99GTP's Avatar
    Apr 2014
    Just did this setup on my 99 and Holy Fudgesicles does that S/C whistle! Thank you so much for the writeup, can't wait to get her out on the highway on my way to work tomorrow!
    Sent from my SCH-I545 using Tapatalk
    Using Tapatalk
  12. #372 Re: Simple Intake (pictures)
    Apr 2014
    Iowa
    Just made myself one of these i think i will be upgrading to an aluminum pipe that is a little longer and when i can make my way to the junk yard get a pcm mount. I dont have that throw ya back in the seat effect anymore when the supercharger kicks in i am still getting full boost and everything seems fine love the sound but am not sure if i am now getting less power or what is happening. Is more air allowing the motor to not have that sudden jump in pressure i am used to and giving me a smoother range?
  13. #373 Re: Simple Intake (pictures)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Have you cleaned your MAF at all? Skip the PCM mount just throw a bungie or zip tie around it.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  14. #374 Re: Simple Intake (pictures)
    SE Level Member jimzssei's Avatar
    Sep 2014
    From the almost dead... On the cheap, 4" ... Torque steered, whined and smiled uploadfromtaptalk1415746074759.jpg
    Sent from my couch
  15. #375 Re: Simple Intake (pictures)
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    and now your engine can enjoy that hot under the hood air......
  16. #376 Re: Simple Intake (pictures)
    Apr 2012
    Dayton, OH
    Mine loves hot air
    2012 F150 STX
  17. #377 Re: Simple Intake (pictures)
    Oct 2013
    michigan
    just thew mine on yesterday. was expecting a large amount of noise from reading some of the comments on here. can hear the blower some more but nothing what i had i mind.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  18. #378 Re: Simple Intake (pictures)
    Cold starts can sound like a shovel on concrete depending on ambient temp and once you drop pulley size the sound comes alive.
    Stock pulleys just don't spin it fast enough for alot of whine.
  19. #379 Re: Simple Intake (pictures)
    Oct 2013
    michigan
    yah i have a smaller pulley on that was given to me but never measured it, i should. updated sig, hadn't been on here in some time.
  20. #380 Re: Simple Intake (pictures)
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Do you have a press on pulley? The mps pulleys have the size written on the side
    Nice intake btw
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
