Check the main supply wire from the alternator, It goes around the back of the engine, over the throttlebody, to the rad cradle along the drivers side dogbone, to the battery. Then check the ground wires that bolt to the front of the transmission, Should be directly below the right side of the drivers side dogbone. Also check the wimpy little body ground that goes 6 inches from the battery to the strut tower.
