Thread: 1/0 gauge wire and high output alternator Question.
Results 1 to 20 of 41
  1. #1 Re: 1/0 gauge wire and high output alternator Question.
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    alt to batt doesn't need a fuse, and neither does batt to batt, but my back battery to amp didn't have fusing so I fused it further up the line, as far as I know, gp's, sunfires etc don't come fused from alt to batt, it goes alt pos, to starter, to batt positive, no fusing, new vehicles do come fused, but its a pain in the ass if you pop that fuse in the middle of the bush or far away from a parts store.
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  2. #2 Re: 1/0 gauge wire and high output alternator Question.
    Sep 2014
    canada
    u should be doing the big 3 to take advantage of the upgraded wire that means pos on alt to batt... eng block to chasis for ground I used the alt bolt and ran 5 inches to firewall and also from ground on batt to body I simply jus overlapped all stock wiring with 0 gauge you cant go wrong just make sure you do the grounds aswell
  1. high output alternator 98 gtp
    By Ricky Garcia in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2014, 11:59 PM
  2. High Output Alternator
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-09-2014, 09:16 AM
  3. high output alternator for 97 gtp
    By blakgtp in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2013, 02:04 AM
  4. High output alternator vs battery
    By deathjunior in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2011, 11:14 PM
