Thread: Knocking problems
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 41 to 60 of 126
  1. #41 Re: Knocking problems
    Quote Originally Posted by chris99gtp View Post
    we did not solder. we used butt connectors so that could be the problem? we did it on the o2 sensor harness.
    Read
    HOW AN OXYGEN SENSOR WORKS
    The O2 sensor works like a miniature generator and produces its own voltage when it gets hot. Inside the vented cover on the end of the sensor that screws into the exhaust manifold is a zirconium ceramic bulb. The bulb is coated on the outside with a porous layer of platinum. Inside the bulb are two strips of platinum that serve as electrodes or contacts.
    The outside of the bulb is exposed to the hot gases in the exhaust while the inside of the bulb is vented internally through the sensor body to the outside atmosphere. Older style oxygen sensors actually have a small hole in the body shell so air can enter the sensor, but newer style O2 sensors "breathe" through their wire connectors and have no vent hole. It is hard to believe, but the tiny amount of space between the insulation and wire provides enough room for air to seep into the sensor (for this reason, grease should never be used on O2 sensor connectors because it can block the flow of air). Venting the sensor through the wires rather than with a hole in the body reduces the risk of dirt or water contamination that could foul the sensor from the inside and cause it to fail.
    The difference in oxygen levels between the exhaust and outside air within the sensor causes voltage to flow through the ceramic bulb. The greater the difference, the higher the voltage reading.
    An oxygen sensor will typically generate up to about 0.9 volts when the fuel mixture is rich and there is little unburned oxygen in the exhaust. When the mixture is lean, the sensor output voltage will drop down to about 0.2 volts or less. When the air/fuel mixture is balanced or at the equilibrium point of about 14.7 to 1, the sensor will read around .45 volts.
  2. #42 Re: Knocking problems
    you f ed up. butt things suck butt. you need to cut the cars harness plug off, then extend it. i just did a 3 foot extension for my o2. no issues.
    that o2 plug has a stainless steal wire, you cant solder it.
    new o2 extension.VVVVVV
  3. #43 Re: Knocking problems
    I did that on my 97^^^^^^^^^^^^, for my 01 I just bought the zzp 02 extension harness.
  4. #44 Re: Knocking problems
    Antioch, IL
    Im gonna say
    Sensor 1, exhaust leak somewhere
    Sensor 2, catless
    2009 Challenger SRT8
    Expert at being gay.
  5. #45 Re: Knocking problems
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I'm not carlexx
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  6. #46 Re: Knocking problems
    Quote Originally Posted by ITHURTZ View Post
    Im gonna say
    Sensor 2, catless
    If it was an exhaust leak his car would run lean and he would get the code P0171 for it.
  7. #47 Re: Knocking problems
    Antioch, IL
    maybe he bent the sensor from the tunnel, been there done that.
  8. #48 Re: Knocking problems
    I think scotty and I hit the nail on the head, he extended the 02 harness with butt connectors.
  9. #49 Re: Knocking problems
    Jun 2012
    Illinois
    I'll check tomorrow
  10. #50 Re: Knocking problems
    Antioch, IL
    meh, I used wire caps once because I melted it on the header, never had a problem.
  11. #51 Re: Knocking problems
    Jun 2012
    Illinois
    am I safe to drive the car right now? Until I have a chance to look at it?
  12. #52 Re: Knocking problems
    Jun 2012
    Illinois
    And can I just use an o2 extension or am I screwed now and can't do that
  13. #53 Re: Knocking problems
    I would just buy a new O2 sensor and either extend the car harness or buy an extension harness.
  14. #54 Re: Knocking problems
    Antioch, IL
    car will be fine to drive.
  15. #55 Re: Knocking problems
    Jun 2012
    Illinois
    i just took a look at what we did. We made the extension coming from the main wiring not on the o2 sensor. I did it before where i would put an o2 sensor extension. What do i do since i can't use the butt connectors?
  16. #56 Re: Knocking problems
    buy a soldering iron, some flux core solder, and shrink tubes.
    if you got a HF near by the iron and tubes will cost like 6 bucks. the solder i get at the shack, 5 bucks.
  17. #57 Re: Knocking problems
    Jun 2012
    Illinois
    Sounds good. I will do that soon and get rid of butt connectors. Also the first o2 looks kind of close to the tunnel. Going to pound that out a little more
  18. #58 Re: Knocking problems
    i just re pounded mine too to the other day. its no fun with the headers installed. i used a 12 inch or so metal shaft with nuts on both sides. all i had was a roofing hammer, or a 10 lb little sledge hammer. baby sledge did the trick. but killed my arm.
    i saw a few vids of guys with headers and in reverse you can hear the o2 hitting. mine made the same sounds till i re pounded it better.
  19. #59 Re: Knocking problems
    Jun 2012
    Illinois
    Mine has a lot of room with the headers installed down there. It's just on a hard angle. I'll throw band clamps on there too. I think it's leaking where the crossover hits the rear header
  20. #60 Re: Knocking problems
    i need to have a friend power brake the car while i watch from under it. that way ill know if anything is hitting. at least see how much it moves under there.
  1. Knocking?
    By Timing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2013, 07:34 PM
  2. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  3. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  4. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
  5. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
