Thread: Knocking problems
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 126
  1. #1 Knocking problems
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    So I just put on the mods that are in my sig and I'm getting shout 3-3.5 degrees of kr.(via torque app) I also am getting this code (which I don't have off the top or my head because I'm at work) that deals with the iat sensor. Short circuit? Torque is telling me that my intake air temp is a constant 140* C. Could this be giving me my problems?
    Thanks,
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Knocking problems
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    IAT might be bad or one of the wires is broke.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Knocking problems
    Jun 2012
    Illinois
    Would that be causing that much knock?
  4. #4 Re: Knocking problems
    Apr 2012
    Dayton, OH
    That I don't know, I can't see your sig because I'm on tapatalk so I don't know your mods.
    2012 F150 STX
  5. #5 Re: Knocking problems
    Jun 2012
    Illinois
  6. #6 Re: Knocking problems
    siggy: 01 gtp- Here to stay-3.4, SD Headers, AL104's HIA, Intense PCM
    check the ait sensor wires, maybe they are cracked up and missing insulation like mine were. you can also clean it.
  7. #7 Re: Knocking problems
    Jun 2012
    Illinois
    Yeah I just have it shoved In there. I'm not worried about just trying to see why the knock. Hoping that's it
  8. #8 Re: Knocking problems
    unless something its hitting like the o2, or the dp to sway bar. or your motor mounts are shot to hell. that could cause KR.
    i was stock, did a u bend delete, that got me from 8* to 5*, did rockers, no tune. zero KR, i did headers today, no KR still. only blips of im rolling and mash it. i think the o2's hitting.
    got the 3.4 in the mail. then ill be tuning a bit.
  9. #9 Re: Knocking problems
    Jun 2012
    Illinois
    That o2 could be hitting. I'll look at that more. Just thought that since the sensor is saying 140*c that it could be changing stuff
  10. #10 Re: Knocking problems
    it could be. cause my intake temps are @ like 160 and higher sometimes.
  11. #11 Re: Knocking problems
    Jun 2012
    Illinois
    Feirnheit or Celsius? Mines celsius
  12. #12 Re: Knocking problems
    Fahrenheit aka degree's usa standard. lol
  13. #13 Re: Knocking problems
    Jun 2012
    Illinois
    Yeah torque is giving me it in Celsius.. Got 3 when doing a second gear pull till 4500 then shut it down
  14. #14 Re: Knocking problems
    Jun 2012
    Illinois
    how much knock is okay? if any?
  15. #15 Re: Knocking problems
    Antioch, IL
    0 on a 3.4
    2009 Challenger SRT8
    Expert at being gay.
  16. #16 Re: Knocking problems
    Jun 2012
    Illinois
    maybe i just got a bad pair of headers.. don;t think it'b be hitting anything downlow. how much clearence should i have between the 02 sensor and the tunnel? Going to try and figure out the iat problem tomorrow. Is there anywhere else i can put the senor other then jammed into where the throttle body and cone meet?
  17. #17 Re: Knocking problems
    Jun 2012
    Illinois
    P0112 is the code
  18. #18 Re: Knocking problems
    Chris go to the settings on torque then click on units and go through everything in there and change it to US stuff, it defaults to metric and Celsius.
  19. #19 Re: Knocking problems
    Jun 2012
    Illinois
    Saying 284* F
  20. #20 Re: Knocking problems
    Check the wiring to the IAT, if its good then I would just get a new IAT sensor. I think that with intake temps that high the pcm might pull fuel, and I know lack of fuel can cause KR.
  1. Knocking?
    By Timing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2013, 07:34 PM
  2. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  3. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  4. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
  5. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
