Thread: How to remove a really stubborn bolt?
Results 1 to 13 of 13
  1. #1 How to remove a really stubborn bolt?
    SE Level Member GrandPrick97's Avatar
    Aug 2014
    Lynchburg, VA
    Ok so I'm trying to take the hood off of the old fender clip so I can replace my fender, but my drill isn't powerful enough and a broke a wrench trying to do it by hand. I know this seems dumb but I could really use some advice and I need to have this done by tomorrow thanks for reading... it's a star head bolt
  2. #2 Re: How to remove a really stubborn bolt?
    SWPA
    That bit, in a socket and use a ratchet.
  3. #3 Re: How to remove a really stubborn bolt?
    This
    Or add it to a breaker bar to crack it loose then use a ratchet..
    Might be overkill though
    04 Comp G.
  4. #4 Re: How to remove a really stubborn bolt?
    Feb 2013
    37.295091, -121.930053
    this thread make me worry about people ....... smh
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: How to remove a really stubborn bolt?
    Aug 2014
    Lynchburg, VA
    Sweet it worked, had to put a 3 foot pipe over the ratchet and I got it off thanks
  6. #6 Re: How to remove a really stubborn bolt?
    what make are those wrenches? cant say ive ever seen one snapped clean off like that, i've had em spread and strip inside in the past.
  7. #7 Re: How to remove a really stubborn bolt?
    Oct 2014
    A mechanic I used to work with called his cheap wrenches 'Fine China' it may be time for a better wrench set.
  8. #8 Re: How to remove a really stubborn bolt?
    Banned
    Jan 2013
    Colorado
    the one was a craftsman
  9. #9 Re: How to remove a really stubborn bolt?
    Apr 2012
    Bancroft. Ontario, Canada
    this.....
  10. #10 Re: How to remove a really stubborn bolt?
    Manual impact driver, you should invest in one for things like this.
    Smack the end with a hammer and that not only provides a shock to the bolt/screw but applys a turning force on the bolt at the same time, they work really well. Though you best make sure the bits you use can withstand the abuse, they tend to crack or break the end off.
  11. #11 Re: How to remove a really stubborn bolt?
    ^^ This
  12. #12 Re: How to remove a really stubborn bolt?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    My girlfriend got me a 19 volt impact wrench for Christmas, I'm sure there are limits to what it can do, but when it zipped out those horribly rusted downpipe bolts... I was wondering where it had been all my life.
    Get one of those!
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  13. #13 Re: How to remove a really stubborn bolt?
    Nov 2011
    NY
    Or make your own magic bolt loosening spray, 50/50 mix - acetone & ATF. Works wonders... Spray, let sit a while and whoola!
    but be cautious, as mentioned in other posts (Bill)... Don't use it near open flame or heated parts!
  1. How to remove this weird screw/bolt
    By GrandPrick97 in forum General Tech Discussion
    Last Post: 12-27-2014, 08:05 PM
  2. Best way to remove broken bolt
    By tms8582 in forum Brakes/Suspension/Chassis
    Last Post: 12-14-2011, 02:48 PM
  3. Stubborn caliper bolt
    By Teancum in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2011, 05:40 AM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
