Thread: Knocking problems
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 126
  1. #1 Re: Knocking problems
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    That's a good idea too. That would be great if that's the reason for all this knock. I have a 3.5 on the way. are the codes/problems contributing to my high kr values?
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Knocking problems
    what plugs you got in the car now?
    and maybe your car is like mine, begging for a tune. my ltft are in check. i got rockers, headers and a 3.4 and 6* of kr. its begging for a tune.
    or its hitting somewhere still...
  3. #3 Re: Knocking problems
    Jun 2012
    Illinois
    AL104's. gapped to .055 i need to check that gap tho. don't know if i feel confident about how they were gapped on install. It has an intense pcm so i thought that would help
  4. #4 Re: Knocking problems
    Jun 2012
    Illinois
    haven't gotten around to my wires yet. i reset my codes a couple days and they haven't came back yet. Today i threw bandclamps onto the crossover and it still seems like i have a leak. don't think my buddy tightened the rear clamp that well since we were getting tired and sick of trying to get that back clamp on. These clamps have to be extremely tight right?
  5. #5 Re: Knocking problems
    If you had a leak you would hear it.
    Sent from A Galaxy Far Far Away........
  6. #6 Re: Knocking problems
    Jun 2012
    Illinois
    I do hear it lol gotta keep tightening those clamps I guess
  7. #7 Re: Knocking problems
    take another look at your o2 sensor, mine was bent nice from hitting the wall. moved the o2 to the cross over pipe today.
    lets see it hit now lol
  8. #8 Re: Knocking problems
    Jun 2012
    Illinois
    Got my 3.5 stock belt size? Or keep the same that I have for the 3.4?
  9. #9 Re: Knocking problems
    Jun 2012
    Illinois
    Got my headers from Corey, shouldve just used the bung he had😡
  10. #10 Re: Knocking problems
    Antioch, IL
    scotty u did it!
    chris, thats the reason why I moved my sensor there. pita way down there, one less headache, no extension needed either.
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: Knocking problems
    Jun 2012
    Illinois
    I wish I would've known that!!!! Car sees less knock with 3.5.. On first pull max i saw was .4 one pull I saw 2.2 tho
  12. #12 Re: Knocking problems
    Jun 2012
    Illinois
    Getting some bad gas millage too, 13 mpg, shouldn't be this bad after a couple pulls and then normal driving... Right? Thinking the wiring to the front o2 is messing it up. Am I correct on that? I haven't had a chance to solder those wires yet
  13. #13 Re: Knocking problems
    Antioch, IL
    sounds like primary sensor. Iv never went below 20mpg on the display no matter how hard I drove. How does it idle I forget.
  14. #14 Re: Knocking problems
    Jun 2012
    Illinois
    Sometimes it'll have a couple little shutters... But other than that car runs and drives well. Just got the kr and if I scan it it shows p1133 but no ses light. Hoping that the wiring to the sensor is going to lower the kr and fix the code
  15. #15 Re: Knocking problems
    Antioch, IL
    Faulty Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1
    - Vacuum leak
    - Faulty Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 harness is open or shorted
    - Faulty Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 circuit poor electrical connection
    Read more: http://engine-codes.com/p1133_pontia...#ixzz3AEpdw3d3
    get a new one and put it in the crossover.
  16. #16 Re: Knocking problems
    o2 in the cross over fixed all my issues. that or get a bigger hammer. yours maybe bent like mine is. yet mine still works.
  17. #17 Re: Knocking problems
    Jun 2012
    Illinois
    Going to hopefully solder my wires tonight. Is there any readings I can see on torque app to see if the soldering fixed my problems?
  18. #18 Re: Knocking problems
    o2 voltage, it should dance up and down 9 2 5 9 3 8 5 3 9 and so on and so forth.
    put it on a page all by is self so it reads as fast as it can.
  19. #19 Re: Knocking problems
    Jun 2012
    Illinois
    At idle I should be seeing that?
  20. #20 Re: Knocking problems
    all the time, up down up down.
  1. Knocking?
    By Timing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2013, 07:34 PM
  2. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  3. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  4. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
  5. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
